Go to Post Being professional means doing things right. Being gracious means doing the right thing. They complement each other perfectly. But I think we should remember to use GP as a guide for our own behavior, not as a yardstick to measure others' shortcomings. - Alan Anderson [more]
Unread 19-01-2017, 16:46
Poseidon5817's Avatar
Poseidon5817 Poseidon5817 is offline
Founder and CEO, DeadMemes Studios
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Poseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud of
Issue with the NavX Library
One of the students on our programming team is having trouble uploading code to the robot. In her build path is:
  • WPILIB
  • Cscore
  • OpenCV
  • Navx Library
  • TalonSRX Library
  • JRE System Library
In Eclipse, the code has no errors; the code shows no issues regarding not recognizing the AHRS class in the NavX library. However, upon trying to upload, the deployer gives an error stating that class AHRS is not found, even though it is fine in Eclipse. build.properties points to the correct library locations for the TalonSRX library and NavX library too.
Sidenote: I had the same issue after upgrading on kickoff, but managed to fix it. I can't for the life of me remember how though.
My FRC History:
2014 - Team 1671: Central Valley Regional Finalist and Chairman's Award Winner, Sacramento Regional Finalist, Archimedes Quarterfinalist
2015 - Team 1671: Central Valley Regional Semifinalist, Sacramento Regional Semifinalist and Chairman's Award Winner, Newton Winner, Einstein Winner
2016 - Team 5817: Central Valley Regional Finalist and Rookie All-Star, Orange County Regional Quarterfinalist and Rookie All-Star, Newton Division
2017 - Team 5817: Return of the bench grinder
Unread 19-01-2017, 17:31
jbc218 jbc218 is offline
FRC #4910 (East Cobb Robotics)
jbc218 is an unknown quantity at this point
Re: Issue with the NavX Library
This year, you no longer have to change build.properties, so whatever changes or additions you made there you should undo. Instead, what you're supposed to do, is put those libraries (navx, talonSRX, or any other user library) into your C:\Users\(current user)\wpilib\user\java\lib folder, make sure to update your build path on Eclipse, and then restart Eclipse. You only have to do that with user libraries, so you don't have to do anything to your wpilib, networktables, opencv, or cscore libraries.
Unread 19-01-2017, 19:14
whitetail's Avatar
whitetail whitetail is offline
FRC #5407 (Wolf Pack)
Team Role: Driver
whitetail is an unknown quantity at this point
I put them in C:\Users\(current user)\wpilib\user\java\lib folder but then it gives me a big ! over the project folder and doesn't recognize the AHRS. Did I miss a step?
FRC Team 5407 -Driver, Programmer and Head Control Systems Engineer
2015 MAR Championship Rookie All Star Award
2015 MAR Hatboro-Horsham District Rookie All Star Award
2015 MAR Hatboro-Horsham District event Winner(Thanks 2590 and 2607)
2016 MAR Hatboro-Horsham District event Winner(Thanks 2607 and 1218)
Unread 19-01-2017, 20:42
slibert slibert is online now
Software Mentor
AKA: Scott Libert
FRC #2465 (Kauaibots)
slibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud of
As noted above, third party libraries are now located in a standardized location.
Please review the updated FRC RoboRIO Java Library Getting Started instructions, which provide details on configuring Eclipse.
Unread 19-01-2017, 23:28
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
That is what I did! Thank you so much everyone, I will pass this on tomorrow!
My FRC History:
