Go to Post I am proud whenever I turn to a team during inspections and say "OK I just need two signatures here and I will go get your sticker, you passed!" - Al Skierkiewicz [more]
Unread 20-01-2017, 19:16
Psychicowl's Avatar
Psychicowl Psychicowl is offline
FRC #3039
Psychicowl is an unknown quantity at this point
Exclamation No Robot Code when uploaded?
During the upload of my code I got a lot of errors and my drivers station doesn't find any Robot Code. My RoboRio is imaged with 2017 and has Java installed. I do have an error in my build.xml file even though I have completely deleted and reinstalled my FRC plugins and NI software. The error in my build.xml says "Default target deploy does not exist in this project".
[console]
Buildfile: C:\Users\WidlcatRobotics\workspace\Steamworks\buil d.xml
Trying to override old definition of task classloader
clean:
[delete] Deleting directory C:\Users\WidlcatRobotics\workspace\Steamworks\buil d
[delete] Deleting directory C:\Users\WidlcatRobotics\workspace\Steamworks\dist
compile:
[mkdir] Created dir: C:\Users\WidlcatRobotics\workspace\Steamworks\buil d
[echo] [athena-compile] Compiling src with classpath=C:\Users\WidlcatRobotics\wpilib\java\cur rent\lib\WPILib.jar;C:\Users\WidlcatRobotics\wpili b\java\current\lib\NetworkTables.jar;C:\Users\Widl catRobotics\wpilib\java\current\lib\opencv.jar;C:\ Users\WidlcatRobotics\wpilib\java\current\lib\csco re.jar to build
[javac] Compiling 13 source files to C:\Users\WidlcatRobotics\workspace\Steamworks\buil d
jar:
[echo] [athena-jar] Making jar dist/FRCUserProgram.jar.
[mkdir] Created dir: C:\Users\WidlcatRobotics\workspace\Steamworks\dist
[mkdir] Created dir: C:\Users\WidlcatRobotics\workspace\Steamworks\buil d\jars
[echo] [athena-jar] Copying jars to build/jars.
[copy] Copying 4 files to C:\Users\WidlcatRobotics\workspace\Steamworks\buil d\jars
[jar] Building jar: C:\Users\WidlcatRobotics\workspace\Steamworks\dist \FRCUserProgram.jar
get-target-ip:
[echo] Trying Target: roboRIO-3039-FRC.local
[echo] roboRIO found via mDNS
dependencies:
[echo] roboRIO image version validated
[echo] Checking for JRE. If this fails install the JRE using these instructions: https://wpilib.screenstepslive.com/s...ller-java-only
[sshexec] Connecting to roboRIO-3039-FRC.local:22
[sshexec] cmd : test -d /usr/local/frc/JRE
deploy:
[scp] Connecting to roboRIO-3039-FRC.local:22
[scp] Receiving file: /usr/local/frc/lib/WPI_Native_Libraries.properties
[scp] Caught exception: scp: /usr/local/frc/lib/WPI_Native_Libraries.properties: No such file or directory
[echo] Deploying libraries
[echo] libHALAthena.so,libcscore.so,libntcore.so,libopenc v_calib3d.so.3.1,libopencv_core.so.3.1,libopencv_f eatures2d.so.3.1,libopencv_flann.so.3.1,libopencv_ highgui.so.3.1,libopencv_imgcodecs.so.3.1,libopenc v_imgproc.so.3.1,libopencv_java310.so,libopencv_ml .so.3.1,libopencv_objdetect.so.3.1,libopencv_photo .so.3.1,libopencv_shape.so.3.1,libopencv_stitching .so.3.1,libopencv_superres.so.3.1,libopencv_video. so.3.1,libopencv_videoio.so.3.1,libopencv_videosta b.so.3.1,libwpilibJavaJNI.so,libwpiutil.so
[scp] done.
[sshexec] cmd : chmod -R +x /usr/local/frc/lib
[scp] Receiving file: /usr/local/frc/lib/User_Libraries.properties
[scp] Caught exception: scp: /usr/local/frc/lib/User_Libraries.properties: No such file or directory
[echo] [athena-deploy] Copying code over.
[scp] done.
[sshexec] cmd : ldconfig
[sshexec] cmd : killall -q netconsole-host || :
[scp] Receiving file: /usr/local/frc/bin/netconsole-host.properties
[scp] Caught exception: scp: /usr/local/frc/bin/netconsole-host.properties: No such file or directory
[echo] netconsole-host
[scp] done.
[sshexec] cmd : chmod -R +x /usr/local/frc/bin
[scp] done.
[echo] [athena-deploy] Starting program.
[sshexec] cmd : . /etc/profile.d/natinst-path.sh; /usr/local/frc/bin/frcKillRobot.sh -t -r;
[sshexec] cmd : sync
BUILD SUCCESSFUL
Total time: 28 seconds
[End Console]
Any help would be much appreciated!
Unread 21-01-2017, 23:57
dmelcer9 dmelcer9 is offline
AKA: Daniel
FRC #0810 (Mechanical Bulls)
dmelcer9 is an unknown quantity at this point
Re: No Robot Code when uploaded?
What's the output if on the driver station you check the logs? (You can access the logs by clicking on the gear icon towards the right of the Ds).
Unread 24-01-2017, 12:37
Psychicowl's Avatar
FRC #3039
Actually I ended up solving the error by just completely reinstalling my FRC plugins and wpilib libraries.
