Go to Post Gracious professionalism is competing with a team one minute, and helping them fix their robot the next. It is cheering for FIRST, rather than just your team, and most importantly: it is looking at the future and saying, "Together, we can do that" - WakeZero [more]
Unread 20-01-2017, 19:37
tkdberger's Avatar
tkdberger tkdberger is offline
SPAAACE
AKA: Edwan Vi
FRC #3494 (Quadrangles)
Rookie Year: 2016
tkdberger is an unknown quantity at this point
Question Java vision example heading not changing
I'm using WPI's vision tracker example, and there seems to be a strange issue: the turn heading doesn't change. I added a call to print the turn value in autonomousPeriodic() to make sure of this.
 * This function is called periodically during autonomous
@Override
public void autonomousPeriodic() {
	// commented out for vision
	// Scheduler.getInstance().run();
	double centerX;
	synchronized (imgLock) {
		centerX = this.centerX;
	double turn = centerX - (IMG_WIDTH / 2);
	// drive with turn
	System.out.println("Turn value: " + turn * 0.005);
	wpiDrive.arcadeDrive(0.5, turn * 0.005);
(The result code is at https://github.com/BHSSFRC/patricias...bot/Robot.java)
The console output looks like this:
Turn value: -0.025
Turn value: -0.025
Turn value: -0.025
Does anyone have any idea why the turn value doesn't appear to be updating?
Unread 20-01-2017, 23:11
wlogeais wlogeais is offline
FRC #2177 (The Robettes)
wlogeais is an unknown quantity at this point
Re: Java vision example heading not changing
Within your Robot.java, line 69 ...if !empty..., this is a dependency for finding at least one contour, is that false?
Unread 21-01-2017, 09:47
tkdberger's Avatar
SPAAACE
AKA: Edwan Vi
Rookie Year: 2016
Lightbulb Re: Java vision example heading not changing
You know what, it probably is. I've been refining our vision pipeline to see if this is the case. Will update when I have answers.
