Unable to deploy project which imports another project
I can import one project from eclipse into another project, and no errors are showing up, but when I try to deploy it, the console says the import does not exist, and it does not work.
Thanks for your help. |
Re: Unable to deploy project which imports another project
You need to have the first project generate a jar, which you can then use in accordance with http://wpilib.screenstepslive.com/s/...arty-libraries
We just tried that, with BREAD-Robot-Core.jar in C:\Users\David Boles\wpilib\java\current\lib, it crashes. If we add:
<fileset file="C:\Users\David Boles\wpilib\java\current\lib\BREAD-Robot-Core.jar"/> <path id="classpath.path"> <fileset dir="${userLibs.dir}" includes="*.jar"/></path> in WPILib's build.xml it seems to work fine. Are we doing something wrong or is this an issue with WPILib's 3rd party library building process? Last edited by david.e.boles : 21-01-2017 at 17:06. |
Whoooops!
Thanks for the tip Joe.![]() Any hints on auto-building our core? |
