NavX Include Error
So, our team tried to download our code for the first *pun not intended* time this afternoon. In the course of this, we encountered an error with the NavX Library. During a normal debug build, we get no errors, and the library include paths are recognized. In the build stage after selecting the deploy option, however, somehow the library is no longer recognized, causing the build to fail. Going into the Properties of the project afterwords reveals that the library is no longer recognized.
This problem is present in this year's code, last year's code (not a problem before the updates), and in a bare-bones, example project with the only changes being adding the path (in theory), including the header file, and creating an object. It is the same in all three instances. Any feedback is appreciated, and thanks ahead of time for your help to get my team to take flight! |
Re: NavX Include Error
Could you post screenshots/full error details?
I had a similar problem when using the Navx for the first time. Link:
http://www.pdocs.kauailabs.com/navx-...o-libraries/c/ Follow all the steps in the link and it should work. Pay special attention to where you put the file downloaded. Hopes this solves your problem. I am programming in java so it might be a different issue for you but it sounds similar to mine. |
I would think that would help us understand your situation a lot better, the only thing I can think of without seeing the error messages is that your NavX libraries did not install correctly.
