My motors are hot for you!
Unread 23-01-2017, 11:04
rlance rlance is online now
FRC #5550
rlance is a splendid one to beholdrlance is a splendid one to beholdrlance is a splendid one to beholdrlance is a splendid one to beholdrlance is a splendid one to beholdrlance is a splendid one to beholdrlance is a splendid one to behold
Gear Sliding down Ramp
I built a player station this past weekend and was trying to get the gear to slide down on its own. I realize I was using polycarbonate and not HDPE like is actually used, but I could not get the gear close to sliding on its own. I wouldn't think the HDPE is that much slicker than the polycarbonate and the specs I found appear to show that HDPE is a little slicker, but not much. Has anyone else run into this problem with their player station?
The angle in the rules says it is 72 degrees from vertical, which is what I am pretty sure I am using.
Unread 23-01-2017, 11:14
Ginger Bread's Avatar
Ginger Bread Ginger Bread is offline
Official Ginger of Team #4941
AKA: Landon J.
FRC #4941 (Team RoboBibb)
Team Role: Human Player
Ginger Bread is an unknown quantity at this point
Re: Gear Sliding down Ramp
My team made this out of wood and the gear has a great deal of friction even when we put lexan on top of the wood to simulate the field.
FRC 4941
Unread 23-01-2017, 11:18
anthonyttu anthonyttu is offline
Texas Instruments Engineer
AKA: Master Chief
FRC #5417 (Eagle Robotics)
anthonyttu has a spectacular aura aboutanthonyttu has a spectacular aura about
lexan is a name brand of polycarbonate
Unread 23-01-2017, 11:19
EmileH's Avatar
EmileH EmileH is offline
#dontbelarge
AKA: Emile Hamwey
FRC #1058 (The PVC Pirates) & SLFF (NE Way You Want It)
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
Polycarbonate and HDPE are NOT the same. HDPE has a coefficient of friction of 0.28 according to this chart, whereas standard polycarbonate (lexan) has a CoF of 0.38.
2016-present: High School Student, FRC 1058 PVC Pirates
Unread 23-01-2017, 11:23
FRC #5550
Yes, I realized we were not using the exact material, but the chart you referenced is showing a bigger difference in co-efficient of friction than what I was finding last night. We will obtain some HDPE and see what happens.
Unread 23-01-2017, 11:26
Billfred's Avatar
Billfred Billfred is offline
It may be easier/cheaper/faster to get some FRP (the white pebbly stuff you see in public bathrooms) from your local home improvement store. That's what's specced for the team versions of the field, and things slide very well down the one we have here at AndyMark.
Unread 23-01-2017, 11:29
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Man, the one time I wish we still had some Regolith sitting around...
2016: Lake Superior WFFA
Unread 23-01-2017, 11:38
FRC #5550
That is great to hear. I'll run and get FRP. Thanks.
Unread 23-01-2017, 11:55
FRC #5550
The team version also has the angle 1.7 degrees steeper, which I assume is to account for the difference in co-efficient of friction between the HDPE and FRP.
Unread 23-01-2017, 12:36
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
I have found the surface of a white board offers little friction. We tried the polycarbonate route and found it less slippery than plywood.
Unread 23-01-2017, 13:46
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
We have HDPE sheets on our wooden chutes. It's not the same texture as the field versions (they use something called "orange peel", which is not commonly available here), but the gears still slide much better than on wood alone. That said, the "static" friction is still high enough that the gears will stick to the chute until you give them a (very) little push. I wonder if the real field has the same behaviour.
Unread 23-01-2017, 13:56
Robosparks2926's Avatar
Robosparks2926 Robosparks2926 is offline
FRC #2926
Robosparks2926 is an unknown quantity at this point
Exclamation Re: Gear Sliding down Ramp
Is there reflective tape on the peg/ platform for the gear placement?
Unread 23-01-2017, 14:04
cpapplefamily cpapplefamily is offline
FRC #3244 (Granite City Gearheads)
Rookie Year: 2015
cpapplefamily has a spectacular aura aboutcpapplefamily has a spectacular aura about
We had observed the same non-slide of the gear. A little spray of some dry lube and no stick.
Unread 23-01-2017, 14:07
Drivencrazy's Avatar
Drivencrazy Drivencrazy is offline
AKA: Clint Ott
FRC #1619
Drivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant future
We had some orange peel HDPE from the scoring platforms in RR. Significantly faster slide than the plywood and polycarb. If your designs are sensitive to the exit trajectory of the gear, I'd get some.
Have not compared to FRP.
Unread 23-01-2017, 14:08
mwmac's Avatar
mwmac mwmac is online now
JWBWIFWWWADD
AKA: Mike MacLean
FRC #2122 (Team Tators)
mwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond repute
This product worked well for us in 2015 to serve as the feed chute surface for totes.
https://www.woodcraft.com/products/slick-strips-3-width
This year, given the width of the loading station and the size of the gear, it made more sense to us to use the frp alternative.
2016 Carson W 2122, 2052, 3538, 41, AZ North W 2122, 125, 498, MQA, Idaho F 2122, 3250, 3513, MQA, CCC W 2122, 9122, 6174, ICA
2015 Tesla SF IDA 2122, 3360, 2960, 1311 IRI SF 2338, 2122, 107, 234 UT F 2122, 3230, 3405, EEA, WFFA, AZ West W 2122, 3309, 5059, ICA
2014 Galileo QF 1717, 2122, 3683, 193 UT W 2122, 2996, 3191, ICA, CCC W 1678, 2122, 9073, ICA
2013 CalGames W 2122, 1678, 4171, Judges Award
2012 Newton QF 2122, 610, 488 Spokane W 2122, 1983, 4082, EEA
2011 Newton SF 1730, 2122, 11 IRI F 3138, 16, 2122, 1730, UT W 2122, 399, 3239, MQA, Seattle F 2122, 488, 2850, MQA
2010 Galileo SF 78, 51, 2122 UT W 1696, 2122, 3405, IDA, Sacramento F 2122, 2035, 1834, IDA,
2009 Sacramento F 2144, 692, 115, 2122, MQA
2008 Newton Sacramento W 2122, 1662, 115, CA
2007 PNW Regional Highest Rookie Seed
"Enjoying traveling to more distant events" since 2007
