Go to Post Robotics is better than Football. Robotics > Football !!! - Arkorobotics [more]
Unread 23-01-2017, 13:52
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
Class ADXRS450_Gyro output angles?
We're using the AD XRS450 gyro module from the KOP this year. We need to know how the angles are output (we're using LabView) from this WPI library function. According to the C++ documentation the get_angle method returns an angle that continues from 360 to 361 and so forth. If so then our drive straight routine will need some pre-processing of the angle data before we use it. I don't want to invent something that might not be needed.
Can anyone verify that the ADXRD450 GetAngle() method does indeed output angles in the 0-360 degree and beyond range?
Unread 23-01-2017, 15:17
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
jojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant future
Re: Class ADXRS450_Gyro output angles?
We just tested with this sensor recently. We found that it did go past 360 (and also -360 if you turn it CCW).
(Disclaimer: We use Java, but that shouldn't matter)
2013 and 2014 - Student (FRC#2990), Programmer (LabVIEW)
2015 and 2016 - Mentor (FRC#2990), Programming (LabVIEW)
2017-Current - Mentor (FRC#997), Controls/Programming (Java)
2015-Current - A/V Volunteer at Oregon events
Unread 23-01-2017, 15:40
wt200999's Avatar
wt200999 wt200999 is online now
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
The angle is continuous, there is no code to wrap in the ADXRS library (so 360 to 361, or on the other hand, 0 to -1 etc). I attached the portion of code that does the actual accumulation which shows this is the case.
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 23-01-2017, 16:22
AKA: Mr Tanguay
Is this the code that runs on the FPGA? If so, it never occurred to me that it would be written in LabView. I can see that all it really does is integrate the rate info over time. No real magic to it.
Thanks, this explains a lot.
Unread 23-01-2017, 18:05
wt200999's Avatar
Texas Instruments
AKA: Will Toth
The gyro code above runs in the background on the RIO itself (would be nice if it was on the FPGA, but doesn't happen in this case). You can find that code snippet if you look in the Gyro Open VI.
However I believe the FPGA implementation is also all done in LabVIEW using LabVIEW FPGA. Due to the parallel nature of LabVIEW it actually lends itself quite well to being compiled onto the FPGA.
Unread 23-01-2017, 16:11
AKA: Mr Tanguay
Thanks for verifying this for me. And thanks for the heads-up about the -360 degree aspect. I need to check to see if the pre-processing accounts for that possibility.
Unread 23-01-2017, 16:48
You don't need to invent anything when dealing with a continuous angle sensor. It's already been invented.
The IEEEremainder function (supported in Java and C++) can take any angle and convert it to the range -180 to +180
You can also use it to find the shortest angle (magnitude and sign) between a setpoint and a process variable.
