Go to Post One of our electrical engineers would bring his kids in every so often, so they could actually see their dad during build season. - Karthik [more]
Unread 23-01-2017, 17:11
sportsmanwesley sportsmanwesley is offline
FRC #4809
sportsmanwesley is an unknown quantity at this point
Angry Adis16448 Not Found
I've been working on getting the ADIS16448 to work on our bot. I have gotten the IMU library for the ADIS and have integrated the example code [url="https://ez.analog.com/blogs/engineeringmind/2017/01/18/using-the-adis16448-imu-in-frc-labview"]. The problem is the device is not registered as found or outputting any information. The power light is lit on the sensor, any ideas on how to fix?
Unread 26-01-2017, 16:40
juchong's Avatar
juchong juchong is online now
Electrical Engineer
AKA: Juan Chong
FRC #2655 (Flying Platypi)
juchong is a jewel in the roughjuchong is a jewel in the roughjuchong is a jewel in the rough
Re: Adis16448 Not Found
Hi sporsmanwesley! Sorry you're having trouble with the sensor! Can you take a look at the connector between the IMU (metal casing) and the circuit board? There's a chance the sensor could have been connected incorrectly during manufacturing. Also, can you check to make sure that the circuit board is properly connected to the MXP port on the RoboRIO? The easiest way to verify this is to make sure the screw holes in the circuit board match up with the mounting holes in the RoboRIO.
Teams I've worked with:My Website: http://www.juanjchong.com/
What I do: Analog Devices iSensor Product Engineer
