Go to Post If that many teams could do it successfully every match this year I will eat my robot. - Jay O'Donnell [more]
Unread 23-01-2017, 22:27
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Robot Scale Recommendation?
We are shopping for a new "robot" scale, the one we have is an older postal scale and we always have to put aluminum bars on top and TARE it before we place the robot on it.
Just curious if anyone had some recommendations for a reasonably priced scale that had a larger top on it that we could almost just set your robot on it?
Under $100 would be ideal, but I dunno if we are going to hit that price point or not.
What kinda of a scale does your team use? How do you know it's calibrated?
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 23-01-2017, 22:43
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Robot Scale Recommendation?
We used to use a scale that was used to weigh soldiers, to make sure they were within army specifications...so we figured it was accurate, and it always agreed with the FIRST scale within a pound. We did have to put 2x4s across it and zero it before weighing the robot.
Since then we've made seriously underweight robots, and haven't worried about it too much. Just use a bathroom scale to make sure the robot is under 100 lbs when it's near the end of build, and we're fine.
Hopefully someone will have a useful answer for you!
I think we borrowed the wrestling scale once, after we moved our build space from Ft Huachuca, to the high school.
Unread 23-01-2017, 22:48
Chris is me's Avatar
AKA: Pinecone
I don't know any that are big enough to just place the robot on them, but I do know of scales with controls / displays that are connected via a wire rather than directly to the unit. If you build your own top for the scale it should meet your needs?
Scales built for FRC robot sized objects generally cost quite a lot.
Unread 23-01-2017, 22:54
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Our Team has this scale - https://www.grainger.com/product/OHA...Platform-1UXK4
It is quite expensive but it is nice to have setup in the corner of the room so we can keep an eye on weight.
Unread 23-01-2017, 23:00
Controls Engineer
AKA: chakorules
I found a "vet" scale, but I wonder how accurate they are.
https://www.amazon.com/W-C-Redmon-Pr...f_rd_i=desktop
Favorite CD quote:
Unread 23-01-2017, 23:13
Retired Starman Retired Starman is offline
FRC #3573 (Ohms)
Retired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant future
A couple of thoughts.
1. Your local veterinarian most certainly has a platform scale. While you wouldn't want to do it often, once you get close to your local robot configuration, haul it over to your vet to weigh. Be sure to count the vet's office as a sponsor!
2. Any scale needs calibration. FIRST does it at events with a set of four 25 lb. weights. You can do the same by going to Walmart (one with a grocery store) and buying four 25 lb. exercise barbells. While there, take them to the meat department. They will have a scale that has been calibrated by some agency of your state's government. This is done often and the scale the meat department uses is quite accurate. Weigh each barbell and mark it on the barbell. Now you have a very accurate set of calibration weights.
A lot of trouble, but you only need to do it once. Then you can use most any scale configuration you come up with.
3. We always encourage teams to maintain a weight budget. As parts are ready to add to the robot, weigh them and record the weight. This way a small scale can be used to weigh a robot, one part at a time. I know, "That's too much trouble."
Dr. Bob
Chairman's Award is not about building the robot. Every team builds a robot.
Unread 23-01-2017, 23:25
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is online now
AKA: Clint Brawley
FRC #0364 (Fusion)
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
We use a bathroom scale during early stages of build season. However, when we get within 10 lbs of the 120 lbs limit, we take our robot to the local UPS store and they are happy to weight it free of charge.
Clint Brawley
USAF 1992-2013
Fusion 364, 2014 Season to present
Unread 23-01-2017, 23:26
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
Since you are most likely planning on climbing a rope this year. Why not get one of those luggage scales (for example) and just hook your rope to that scale, zero it, and then have your robot "climb the rope" (or just figure out a way to attach some rope to your bot.
Team 3991: Driver since freshman (2015-), Captain since sophomore (2016-), CADer
"The human condition is not perfect. We are not perfect specimens, any of us. We're not robots." - Michael Ovitz
My posts may or may not reflect the views of my team, they are my opinions, and mine alone.
Unread 24-01-2017, 01:28
chapman1's Avatar
chapman1 chapman1 is offline
FRC #3688 (Suttons Bay Norsemen Robotics)
chapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond repute
We have access to a digital scale with a remote readout. This is handy because once the robot is balanced on a regular bathroom-type scale, the readout is usually obscured. We lay a couple of pieces of aluminum channel on it, zero the scale, and then balance the robot on top of them.
If we didn't have that scale, I think I'd try 2 bathroom scales and lay a couple of 4-foot 2x2's between them, zero both scales and then put the robot on the 2x2's. Add the two indicated weights together and there you go.
Older, but still somewhat coherent.
Unread 24-01-2017, 01:58
RoboChair's Avatar
AKA: Devin Castellucci
use 2-4 bathroom scales and add up the total weights to get easy results.
12 Years and counting! Over a third of my life has been spent with FRC.
Unread 24-01-2017, 02:12
Max Boord Max Boord is offline
FRC #0179 (The Children of The Swamp)
Team Role: Tactician
Max Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant future
This also has the advantage of showing weight distribution. Somewhat useful since weight distribution can noticeably effect performance of some drivetrains.
1523 (2011-2014)
1065 (2014-2016)
3932 & 4592 (2016)
1592 (2017)
Unread 24-01-2017, 07:37
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
We have been using this scale with a piece of plywood on top for 5 years. Never had an issue with it.
https://www.amazon.com/gp/aw/d/B001A...40_FMwebp_QL65
Unread 24-01-2017, 07:43
Controls Engineer
AKA: chakorules
Wow...what a great idea! Thank you for this idea.
Favorite CD quote:
