Motor Controllers Stop Working Below 50% Power in Labview
Rather than gear down our motors, we are trying to just drop the percentage of the power going through the motor controller in Labview. This works until we hit 50%(.5). Anything below 50.1% no longer works, as if no signal is going through to the motor controller. It is a spark motor controller if that helps.
![]() Last edited by RoboBucs : 26-01-2017 at 16:51. |
Re: Motor Controllers Stop Working Below 50% Power in Labview
You are attempting to use a logic operator on floating point values.
The output of a logic operator is 1 or 0. If you want to use a button to control the motor, here are some examples: http://www.team358.org/files/program...ControlofMotor Or try one of these two variations for an axis control, just substitute a single motor for the Drive: ![]() Last edited by Mark McLeod : 26-01-2017 at 17:03. |
So like this?(Asking since I'm using a button layout instead of joystick)
Edit: This still only works above 50% ![]() |
Depending upon various factors, you need a certain amount of power to overcome the friction and inertia in your system. In prior years, that amount was about 25-30% power before the robot started moving.
50% seems a little high, but not unreasonable. |
We figured it out, I misread Mark's reply, his solution corrected the issue. I appreciate the help!
