Go to Post Can't engineers be jesters? - danielkitchener [more]
Unread 28-01-2017, 23:41
phurley67 phurley67 is offline
Programming Mentor
phurley67 is an unknown quantity at this point
CAN Talon / Test Mode Crash
Using robot builder, and the latest software from CTRE. If I create a project with a single subsystem, and in that subsystem a single CAN Talon. When the code is deployed, and the robot enabled in test mode we get the following error.
Any ideas on how to resolve this? We do not use test mode a lot, but it does come in very handy when, well testing robots...
<TagVersion>1 <time> 06.899 <count> 1 <flags> 1 <Code> 1 <details> ERROR Unhandled exception: java.lang.NullPointerException: value cannot be null at [edu.wpi.first.wpilibj.networktables.NetworkTablesJNI.putString(Native Method), edu.wpi.first.wpilibj.networktables.NetworkTable.putString(NetworkTable.java:588), edu.wpi.first.wpilibj.livewindow.LiveWindow.initializeLiveWindowComponents(LiveWindow.java:51), edu.wpi.first.wpilibj.livewindow.LiveWindow.setEnabled(LiveWindow.java:74), edu.wpi.first.wpilibj.IterativeRobot.startCompetition(IterativeRobot.java:93), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:247)] <location> edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:249) <stack>
<TagVersion>1 <time> 06.900 <message> Starting live window mode.
<TagVersion>1 <time> 06.901 <message> Initializing the components first time
<TagVersion>1 <time> 06.901 <message> Initializing table for 'Subsystem 1' 'CAN Talon 1'
<TagVersion>1 <time> 06.902 <message> Error at edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:249): ERROR Unhandled exception: java.lang.NullPointerException: value cannot be null at [edu.wpi.first.wpilibj.networktables.NetworkTablesJNI.putString(Native Method), edu.wpi.first.wpilibj.networktables.NetworkTable.putString(NetworkTable.java:588), edu.wpi.first.wpilibj.livewindow.LiveWindow.initializeLiveWindowComponents(LiveWindow.java:51), edu.wpi.first.wpilibj.livewindow.LiveWindow.setEnabled(LiveWindow.java:74), edu.wpi.first.wpilibj.IterativeRobot.startCompetition(IterativeRobot.java:93), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:247)]
<TagVersion>1 <time> 06.904 <message> WARNING: Robots don't quit!
<TagVersion>1 <time> 06.905 <message> ---> The startCompetition() method (or methods called by it) should have handled the exception above.
Unread 29-01-2017, 00:02
SamCarlberg's Avatar
SamCarlberg SamCarlberg is online now
GRIP, WPILib. 2084 alum
FRC #2084
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
Re: CAN Talon / Test Mode Crash
Can you share the main Robot class?
WPILib
GRIP, RobotBuilder
Unread 29-01-2017, 10:00
Programming Mentor
Found the problem, we were using CTRE libraries downloaded around kickoff. There was newer libraries on their website. Downloading them, rebuilding, and deploying fixed the problem.
Thanks
FYI we are now using 4.4.1.9
http://www.ctr-electronics.com/hro.h...ical_resources
