Go to Post There are always rules we don't agree with, just like in life. Our character is defined by how we respond. - Mr MOE [more]
Unread 01-02-2017, 19:00
JoeyDaPanda's Avatar
JoeyDaPanda JoeyDaPanda is offline
AKA: Joey
FRC #6324 (The Blue Devils)
Rookie Year: 2017
JoeyDaPanda is an unknown quantity at this point
VictorSP causes "Robots don't quit!"
Basically the title. When we use VictorSP's in Eclipse it gives us the "Robots dont quit" error in the driver station. The console updates so quickly so we cant copy it out. Any help appreciated.
Unread 01-02-2017, 19:19
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: VictorSP causes "Robots don't quit!"
"Robots don't quit" (at least in this context) likely means you're not sending commands to the Victors fast enough. Try disabling MotorSafety using:
VictorSP.setSafetyEnabled(false);
Unread 01-02-2017, 20:57
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
That wouldn't be legal for comp would it?
Unread 01-02-2017, 21:04
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
This is completely legal. There's no rule that require you to have safety enabled on your motor controllers (or that you even use the three official languages, so issues arrive with that). It simply means that your motor controllers will not continue to move your motors if they get disconnected and stop being updated. It's usually a good idea to keep this on, but not always.
If you can use NetConsole or RioLog to copy out the error exactly, that would be nice. The "Robots Don't Quit!" error simply means your code has crashed and is now restarting.
F4 Network Website Designer
2010-2012: A Whole Buncha FLL Teams; Team Spirit, Gracious Professionalism Award winner
2015-Current: FRC 1982, Captain, Electrical Lead
Beginning FIRST Volunteer
Moderator on the FIRSTwiki
Unread 01-02-2017, 21:05
cgmv123's Avatar
AKA: Max Vrany
Under what rule? There are no restrictions on software as long as it
  1. Is publicly released before kickoff/developed after kickoff.
  2. Runs on a RoboRIO with the correct firmware/image requirements.
Unread 01-02-2017, 21:24
I meant it as a question not as a statement.
Unread 01-02-2017, 22:05
No, that would say that outputs not updated often enough. Like Bkeeneykid said, it means the code crashed. One common cause is resource overallocation (eg opening PWM 1 twice).
Unread 02-02-2017, 18:17
AKA: Joey
Rookie Year: 2017
To anyone still lurking:
Just to make sure, where do I put the import and following code?
Currently the related code we have is in our Robot.java
VictorSP V1 = new VictorSP(1); // Left motor
VictorSP V2 = new VictorSP(0); // Right motor
V1.set(1); // Set speed to 1
V2.set(1); // Set speed to 1
Unread 03-02-2017, 22:42
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
That depends on the type of project you've created. If it's a command based robot project, then hardware components (like motors) are usually encapsulated and controlled through a "Subsystem" class.
There's example code for subsystems here: https://wpilib.screenstepslive.com/s...ple-subsystems
and general information on the command based project here: https://wpilib.screenstepslive.com/s.../13809/c/88893
If you're using just a plain iterative robot project without calls to a Scheduler class / commands / subsystems, then the motor objects would typically be class variables of Robot.java, instantiated in the constructor, and the .set() methods would typically be called from within the TeleoperatedPeriodic() and AutonomousPeriodic() methods depending on what you're trying to do.
Regarding imports, those always go in the same place within a .java file. At the top preceding the line that specifies the class name. Eclipse will automatically put it in the right spot if you right click the red underlined text and select the add import option.
http://team2168.org
