Go to Post Woo for speculation! - Eugenia Gabrielov [more]
Unread 04-02-2017, 14:45
spyguy518 spyguy518 is offline
FRC #2147 (CHUCK)
Rookie Year: 2015
spyguy518 is an unknown quantity at this point
Switching Between Two Cameras in LabView
We have figured out how to run two cameras in LabView (display image from both cameras on Dashboard) at low resolution. But we are trying to figure out a way to use a button on our remote to toggle between cameras, in order to be able to run at a higher resolution. Does anybody have any ideas that could help???
Unread 04-02-2017, 18:01
flemdogmillion's Avatar
flemdogmillion flemdogmillion is offline
Programmer, Builder, Driver...
FRC #3007
Rookie Year: 2015
flemdogmillion will become famous soon enoughflemdogmillion will become famous soon enough
Re: Switching Between Two Cameras in LabView
The Search function of Chief Delphi would be very helpful here.
Team 4506: 2015-2016
Team 3007: 2017
Jack of all trades except C++ & Java
Unread 05-02-2017, 17:50
TigerVision TigerVision is offline
FRC #3654
Rookie Year: 2016
TigerVision is an unknown quantity at this point
Originally Posted by spyguy518 View Post
We have figured out how to run two cameras in LabView (display image from both cameras on Dashboard) at low resolution. ???
Can you give a little more detail about how you run two cameras in LabView? I followed the instruction from another thread "2 cameras": duplicate the initial USB 0 camera setup in the default project code Vision Processing.vi for a second camera, change the values for the second camera like USB 1 and camera 2. At the Dashboard, I can see the images from either camera or camera 2, but not both at the same time.
Did you do anything special to get it working ?
Thanks!
Unread 07-02-2017, 13:10
grosh grosh is offline
FRC #2147
grosh is an unknown quantity at this point
You have to lower the FPS to 10 and set the Compression to 50% in the dashboard on each of the cameras.
