Go to Post A robot is never "complete" - [more]
Unread 07-02-2017, 09:01
bobbysq bobbysq is offline
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud of
3D printable gear hook
I modeled the hook from the end of the lift peg so teams can 3D print it and get their own.
https://www.thingiverse.com/thing:2091279
Unread 08-02-2017, 12:26
Rookie Year: 2015
Re: 3D printable gear hook
A bit of an extra note since I lost the ability to edit.
After printing it, it appears that it has a very tight fit in the spring. In fact, it's so tight that you need to install it by actually screwing it in to the spring, letting the metal dig through the plastic. Because of this, you will want to use a good amount of infill to keep it from shearing. I printed it at 20% and I nearly snapped it trying to get it in, so you may want a bit more if you're worried.
Unread 08-02-2017, 17:12
chapman1's Avatar
chapman1 chapman1 is offline
FRC #3688 (Suttons Bay Norsemen Robotics)
chapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond repute
Thanks for sharing!
Older, but still somewhat coherent.
