Am I sending you the right signals?
Unread 11-02-2017, 13:18
NolanGZ3452's Avatar
NolanGZ3452 NolanGZ3452 is offline
FRC #3452 (GreengineerZ)
Team Role: Driver
NolanGZ3452 is an unknown quantity at this point
Retaining Rings Sticking Outisde of Frame
My team had a question about the frame perimeter rules, we have a few roller shafts sticking outside our frame perimeter about a 10th of an inch with a retaining ring and was wondering if this is legal.
According to the rules:
R01. The ROBOT (excluding BUMPERS) must have a FRAME PERIMETER, contained within the
BUMPER ZONE, that is comprised of fixed, non-articulated structural elements of the ROBOT.
Minor protrusions no greater than ¼ in. (~6.3 mm) such as bolt heads, fastener ends, weld
beads, and rivets are not considered part of the FRAME PERIMETER.
TL;DR are retaining clips considered a fasteners?
Thanks!
Unread 11-02-2017, 13:22
Mechvet Mechvet is offline
Electromechanicad Mentor
AKA: Craig Hickman
FRC #0114
Mechvet is a jewel in the roughMechvet is a jewel in the roughMechvet is a jewel in the rough
Re: Retaining Rings Sticking Outisde of Frame
The purpose of a retaining ring is to keep a shaft from leaving a designate location, therefore one could easily argue that it FASTENS the shaft in place.
Unread 11-02-2017, 15:58
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
I would probably see it as a minor protrusion if I were inspecting you. Would probably need to see it in person to be more sure.
Unread 11-02-2017, 16:59
Robo Hamsters Robo Hamsters is offline
AKA: Matthew Vesperman
FRC #4466 (Robo Hamsters)
Robo Hamsters is on a distinguished road
Yes, a retaining ring is a fastener, but, they are placed in a groove on a shaft, or pressed onto a shaft. Either way the shaft extends past the fastener and as such would be beyond the frame perimeter itself. The portion beyond the fastener is still the shaft and not part of the fastener.
To be absolutely sure though, you should ask in the official q&a.
FRC 4466
FTC 7042
2013 Washington DC Regional Finalist
Unread 11-02-2017, 17:17
Nolan,
An inspector would have to see to make a ruling but in my experience, a clip on a shaft is usually pushing against a bearing. Most such assemblies will end up being more than 0.10" beyond the frame. In any case, the end of the shaft is the protrusion.
