The 1 bin confusion.....
one big thing my team discovered today....if you have 1 bin has your tallest stack, so all the bins are jsut randomly on the floor. and if there is one bin thats on its side, does it count as two? its clearly more than 1 unit of measure the stack height, but 1 container is technically not a stack. the rules say it will be release at a later date, the exact height of all the measurements on the stick woodie had at kickoff. so does any have any ideas? is it counting as a stack of 1....or of 2
According to everything I've seen (from the kickoff, Dave Lavery's demonstration), stacks are based on height, not bin amount.
A bin on its side, breaking the plane of the second level, counts as a stack two bins high, nested properly. Additionally, one bin sitting bottom down on the floor, with another bin, short side down, sitting on top of it, is worth a stack three tall. This is just what I believe to be viable in the rules, and game scoring methods. If I'm wrong, someone please correct me. |
Correct, but remember that if you have one bin one its side (counting as a multiplier of 2) and 4 other bins on the floor, then you total points is 6, not 8. Stack height (2) times your base bin amount: Total number of bins (5) minus stack height (2) times for a total of 3.
Hope this helps! |
What about only 1 bin?
If your alliance only has 1 bin total in the scoring position at the end of the match that bin counts as the multiplier and then your box score is 0.
SC8: Quote:
where did you get 8?? ok, say there is 7 boxes, all just thrown about your scoring zone. so the tallest stack is 1, but now, say 6 of those 7 boxes are right side up, but one is on its side. so now that one counts as your tallest box, and does it count as 2 or 1 box? so is your score 6 or 12
#7
It would...
The way I read the rules is it would be 12.
#8
Check out rule 7.6: "The total base score is then multiplied by the height in whole Stack Height Units (SHU) of the multiplier stack. A whole Stack Height Unit (15-1/4 inches) is the height of an individual container as it sits flat on its bottom." The key here is the value of Stack Height Units, regardless of the number of bins actually used. So, if 1 box created a SHU of 2, then 2 (not 1) is subtracted from the total number of bins to calculate your base score. |
#9
Base Score = 5 (7 total minus SHU of 2) Total Score = 2 * 5 = 10 |
#10
7.6
"All containers within the alliance’s scoring zone will be worth one point each EXCEPT the containers in the tallest stack." and "Containers in the multiplier stack are worth zero points each." The multiplier does depend on height. Base score does not. There, it's just how many physical bins are not in the tallest stack. And the answer is 12. Last edited by Winged Globe : 05-01-2003 at 19:28. |
#11
From what I hear, if it is one bin, then it only counts as ONE. NOT two, NOT three.
#12
we assumed as well that if its one bin, regardless or orientation, that it counts as one, since one is technically not a stack anyway. so the score would be 6
#13
Stack Height Measuring device," as stated in rule 7.6. |
#14
Disagree...
I beleive that a stack can be considered one. What if there is only one box in the scoring position. This is the stack multiplier correct? Then it would be considered a stack and count for zero points.
#15
Re: Disagree...
| Tossing a bin at the ramp in HP | Cory | Rules/Strategy | 12 | 04-06-2003 12:13 |
| Illegal human player bin placement | Mike Soukup | General Forum | 29 | 01-04-2003 21:17 |
| Where to find a bin? | Krystal314 | 3D Animation and Competition | 3 | 18-01-2003 12:56 |
| Bin Stacks | Brad Swindell | Rules/Strategy | 7 | 05-01-2003 19:47 |
| Additional Hardware list confusion | archiver | 2001 | 4 | 23-06-2002 22:29 |
