Optical Sensor Manual/Function list?
Hello,
I am fairly new the the Pbasic program but somewhat familiar with the langauge itself. I'm wondering if there are any manuals on the sensor programming, just a list of possible functions, variables, actions etc. I've browsed through the 350 some page manual and couldn't find anything on it. Any clues? Thank you in advance! |
I haven't come across any manuals.
But, you just hook up the light sensors to the rc digital inputs, and check whether the input is 1 or 0, one corresponds to the signal being sent back, ours is 0 for some reason. Well basically with that you can do an if statement and do something based on that input. There's a knob thing on the back of it to change the sensor threshold. I'm using reference to last year's sensors, because we DIDN'T receive this years sensors yet... |
I can see the light!
Okay, just a digital output, that's easy enough to work with. Thanks for the info, proves i need to do some more research on the programming. ![]() |
![]() i am still a little confused. there are four wires on last year's optical sensor. one for power, one for ground, but what do the last two do? |
Re: optical sensor
#7
ahhhhh. and thanks for including the link. missed that one.
#8
Hmmmm
I was wondering about how a digital signal could be used to create a sort of "rating" on the strength of the optical sensor's reading. I was thinking that a BYTE variable could be used to store the eight previous readings from the sensor in its bits. Each loop would push the bits back one and get rid of the oldest reading. Would he sum of the eight bits be a rating, from one to eight, of how "strong" the sensor's reading is?
I haven't had a chance to test how accurate these things are, and I was figuring that a robot could start to do stupid things if it reacted to an extraneous reading of "1" from the sensor when there really was no reflective tape at all in its line of sight. |
#9
well, everytime you check lets say the light sensor is on...for all 8 bits.
It tells you its been there for a long time, or however long your cycles for each bit are. Combining the bits and using that integer wouldnt really help, example input assuming your doing right to left bit logic all 8 bits are 1...signal 255(254 rounded down automatically in debug at least), then lets say you shift over one bit, 254(no signal 1 bit), no signal for 2 bits consecutively, 252...248...240...224....192....128....0.... I guess that would work, lets show going up input from no lights to ful lights 1...3....7...15.....31.....63.....127....255(254 rounded) so lets say you get 3 in a row, and then 5 consecutive no signals 128+64+32+0+0+0+0+0 224... you get 224 for a run with no signal if you have any questions about this let me know, this is just some bit logic, might help understand it 1...2...4..8.16.32.64.128.256.512.1024.2048.4096 goes right to left each 1 in binary counts as first num and moves up to find sum its (2^n)-1 = 256-1 = 255, its 254 on the default code because two 255's consecutively is a reset - Ryan Last edited by rwaliany : 07-01-2003 at 01:38. |
#10
It sounds to me like you want to measure the intensity of the light returned? If so, read ahead, otherwise, skip this post.
Quite frankly, this is <i>impossible</i>. Why? Because, the light sensor is a switch. It has two valid outputs: on or off. In essence, this means that it is a digital sensor, representing a binary 1 or 0: on or off. In order to measure the intensity of the light, the sensor would have to output some value that fits into a range; say 0 to 255. That would qualify it as an analog sensor. Hence, whenever you have something that is either on or off, it is labeled as a digital signal/sensor. Glancing above it looks like you're trying to keep some sort of record of the last 255 states of the light sensor... I dont see how this could assist much. The resulting byte will not be an intensity measure. To sum it all up, you can not measure the intensity of the light (no way reliably). This can also be seen by the little schematic on the side of the light sensor (LAST YEAR BECAUSE WE HAVENT GOTTEN THIS YEAR'S GRR). It details four connections: two inputs (V+, V-), and two outputs. The two outputs are in a switch circuit... one is on the other is off, or vice versa. Although some sort of variable resistor <b>may</b> be used in the circuitry of the sensor, <b>no</b> variable resistor is detailed in the schematic. Bleh, all this rambling has gotten me off topic... it's a digital sensor, on or off, no way to measure intensity.... only to measure the intensity at which the switch flips (which reminds me there must be a variable component in there because of the wheel on the back....). Time to explore the other threads. Hope this helps clear things up. |
#11
you could sum the values of the bits...
--------------------code------------------- sensorPower = sensorReadings.bit0 + sensorReading.bit1 + ... + sensorReading.bit8 This would yeild a value between 1 and 8 that would increase and decrease in a linear fashion. |
#12
#13
There's a miniature dial you can turn to change the sensitivity of the optical sensor. Theoretically, if you had multiple optical sensors directed towards the same area, you could determine the intensity of the light which you're viewing with a very crude resolution. The kit comes with three optical sensors, so you can have three different intensities of light to measure, in theory.
Keep in mind that I have not tested this at all, it's just a thought that's floating around in my head, and this seemed like the best place to share it. <edit> But alas, this is not a photosensor. It is measuring whether or not it can see (for lack of a better term, at the moment) the reflection of its own emitted light. This post is entirely irrelevant, and should be disregarded by anyone interested in programming for the optical sensor. </edit> Last edited by FotoPlasma : 07-01-2003 at 04:37. |
#14
Hmm
You're right, that should work...
Your idea could be used to measure intensity/distance... roughly anyways... But, I dont think it would be very practical/accurate with only 3 sensors.. also need to consider that you might be using sensors for line following.. oh well i guess that's what the $200 for electronics is for... an array of light sensors :-) Props on the very creative idea. |
#15
You aren't limited to the 3 optical sensors in the kit. First, you can use an unlimited amount of the banner optical sensors, per the list formerly known as the additional hardware list. You also have the $200 from digikey or Future. I'm sure you can find an optical sensor that will give you an analog signal based on the intensity.
| TEAM CONTACTS: SIGN UP HERE!!! | archiver | 2001 | 2 | 24-06-2002 03:51 |
| Wheres the list, whats the secret? | archiver | 2001 | 3 | 24-06-2002 01:31 |
| Full list of teams & competitions | archiver | 2001 | 14 | 24-06-2002 00:52 |
| Team list & Events | archiver | 2000 | 2 | 23-06-2002 22:39 |
| Suggested list of things to bring to the regionals | Andrew Wyatt | Technical Discussion | 1 | 06-03-2002 14:41 |
