In the section Initialize Inputs & Outputs I have noticed that all the pwm's which are normally set to start at 127 are totally missing for this years default code. Did anyone else notice this? Was the starting value necessary or was that just extra stuff that really wasnt needed?
err
I would be too scared to try the program without it. It might work. It might not. I know if your NOT using the new RC you have to initialize them or you might get some unwanted feedback, like a kick.
But yeah, if first could give us a default code when there isn't a working compiler, I think there is a good chance that we still need the initialization and they just forgot it. Serin should overwrite any variables that are in its call, otherwise set it to an arbitrary ZERO(0 or 127). Last edited by rwaliany : 07-01-2003 at 20:56. |
I assume you are referring to the fact that the Serout now only has 14 arguments instead of the old 18? In that case, it will (and always has!) be just fine. If you don't output a variable, the Output uP will just set them to 127.
--Rob |
I was referring to the following lines not present in this years default program: p1_x = 127 'Port 1, X-axis on Joystick p2_x = 127 'Port 2, X-axis on Joystick p3_x = 127 'Port 3, X-axis on Joystick p4_x = 127 'Port 4, X-axis on Joystick p1_y = 127 'Port 1, Y-axis on Joystick p2_y = 127 'Port 2, Y-axis on Joystick p3_y = 127 'Port 3, Y-axis on Joystick p4_y = 127 'Port 4, Y-axis on Joystick p1_wheel = 127 'Port 1, Wheel on Joystick p2_wheel = 127 'Port 2, Wheel on Joystick p3_wheel = 127 'Port 3, Wheel on Joystick p4_wheel = 127 'Port 4, Wheel on Joystick 'p1_aux = 127 'Port 1, Aux Analog 'p2_aux = 127 'Port 2, Aux Analog 'p3_aux = 127 'Port 3, Aux Analog 'p4_aux = 127 'Port 4, Aux Analog It used to be directly below this: '---------- Initialize Inputs & Outputs -------------------------------------- Out7 = 1 'Basic Run LED on RC Out8 = 0 'PWM1 LED - Green Out9 = 0 'PWM1 LED - Red Out10 = 0 'PWM2 LED - Green Out11 = 0 'PWM2 LED - Red Out12 = 0 'Relay1 LED - Red Out13 = 0 'Relay1 LED - Green Out14 = 0 'Relay2 LED - Red Out15 = 0 'Relay2 LED - Green now its not there. I was wondering if I needed to add it or if the robot would run fine without it |
Those are actually fairly worthless. Any variables you are inputting get read in at that first Serin, overriding anything you choose to initialize them with. As long as you still have the VAR statements (ie p1_x VAR byte), you'll be just fine.
