does anyone know the ruling of putting the reflective tape similar to the bins, on your robot?
Adhesive tape for non-insulating purposes is specifically disallowed (See fig 4-1).
I wonder how hard it is to make some other surface retroreflective, or if there is some other retro-reflective material you can buy. Eric. |
what about the actual reflectors that Banning makes, not the adhesive tape but hard solid reflectors... like bike reflectors?
while i don't know about putting a bike reflector on the robot (even if it sounds illegal to me), what i want to know is
WHY? the only thing i see coming out of it is getting other robots, maybe even your ally, to go to you thinking your bot's a stack, and then they just try to kill your bot instead of the stack... that can't be good and it would probably be ruled as your fault |
If you can claim that the reflectors are a non-functional decoration, then it would be allowed.
Chances are the other robots will not start in such a position that they will be able to "see" your tape anyways. |
Non-Functonal Decoration
This wouldn't classify as a non-functional decoration as it would the possibility of affecting match outcome. This would seem to violate part 2 of Rule M9. Actual reflectors could probably be used some other way, at least until there's a team update on this matter.
#7
hey fridge Thanks for you input. I guess it's time I whip out the rule book again! hehe I guess it's a good idea for a designer to actually know such rules as these..
#8
np
No problem. Our team had just gone through the same idea yesterday and had run into the same problems. It's just a brainstorming idea, but i remember that's one reason why we couldn't do it.
#9
How insightful
But we are allowed to jam their RF signal right?
#10
Re: How insightful
See following thread: http://www.chiefdelphi.com/forums/sh...threadid=16783 |
| reflective tape | esellers | Technical Discussion | 8 | 22-01-2003 19:10 |
| Reflective tape on boxes | S2Taz | General Forum | 1 | 20-01-2003 17:24 |
| How is reflective tape applied to HP crates? | Dr.Bot | General Forum | 2 | 06-01-2003 15:17 |
| Substitutes for reflective tape? | Oakridege_665 | Technical Discussion | 1 | 23-01-2002 11:44 |
| Reflective tape in the kit. | Anton Abaya | Technical Discussion | 13 | 11-01-2002 14:16 |
