Our team was considering using a vacuum to lift containers. Any suggestions? And what do the rules say about this? Any information at all would be helpful and greatly appreciated!
I think the rules say that you can't use vacuums in the competition. Not sure though, can someone confirm this?
Rule M12 states that "only the allowed air cylinders may be used to generate vacuum," so a vacuum can be used.
I thought the air can only go one way in those cylinders, which means that it's only a one time use unless you can somehow save up the air in there.
Rule M12 States
Vaccums are legal as long as supplied pneumatics are the only pneumatics used and they are possible with the kit of parts supplied.
#7
Creating a vacuum with the cylinders is very easy. Start by pushing the rod all the way into the cylinder. Now, put your thumb over the lower port and pull on the rod. Notice that your finger gets sucked in a little? That's a vacuum!
#8
NO OTHER DEVICES
I THINK THERE IS A RULE THAT SAYS NO ADDITIONAL PNEUMATIC DEVICES......THAT MEANS NO VACUME PUMPS!!!!
GET IT OUT OF UR HEAD!! -SIR STATE THE OBVIOUS ALOT |
#10
Re: NO OTHER DEVICES
And do you like being talked to in all caps? CAPS ARE THE EQUIVLANT OF SCREAMING IN TYPE. Would you want to be screamed at? I know I don't like to be, try and use proper capitalization or no capitalization at all. Greg |
#11
In 2000, we had this cool thing with the pneumatics called a Vaccum Ejector that turned pressure into an equivalent vaccum. Perhaps FIRST should provide them again...
#12
What is the challenge in that. I think FIRST has purposly made it harder than that to make a vacuum.
#13
i thought about this but didn't want to risk it not working (being a rookie team) but if it works , more power to ya
#14
creating vacuum with air cylinder
You can create a vacuum pump with the cylinder and two check valves, but those aren't allowed, right? You can perform the function of the check valves with solenoid valves--a bit of a hack but should work.
Now, is there anything in the rules to forbid you capping off the 2x4 extruded aluminum pieces and creating vacuum tanks? |
#15
Re: creating vacuum with air cylinder
On a related note: Theres a way to make your robot have ALOT more air pressure stored then you have in the canisters using extrusions, and I believe it would be legal. so ponder away... |
| pic: Another unsed stacker, wings down | CD47-Bot | Robot Showcase | 11 | 30-04-2003 21:36 |
| how many of u actually used the stacker if u had one? | HolyMasamune | General Forum | 21 | 14-04-2003 13:12 |
| A stacker repents... | Jason Haaga | Rules/Strategy | 24 | 03-03-2003 19:10 |
| Image Discuss: Team 753 Working on the Stacker | CD47-Bot | Robot Showcase | 2 | 22-02-2003 01:05 |
| Next Question - Check Valve | archiver | 2001 | 7 | 23-06-2002 23:18 |
