Go to Post p.s. note that 5-1/2 hours in the car with your daughter on the way to IRI is NOT the same as 10 hours in the van with seven members of Team 116 on the way to IRI. One is a wonderful familial experience, the other is an opportunity to go insane. - dlavery [more]
Unread 13-01-2003, 16:44
mistresshawk's Avatar
mistresshawk mistresshawk is offline
#1083 (The CREW)
mistresshawk is an unknown quantity at this point
Help just getting the thing to GO!
Do I feel lost? Totally. We're all sitting here, and we're trying to hook up the RC to the battery. Everyone is all ' you shouldn't connect the RC directly to the battery ' and to be frank, we're all just sitting here without an idea between us. Help!
Hawke
' There are very few problems that can not be solved with orders ending with "or die."'
Unread 13-01-2003, 16:57
srawls's Avatar
srawls srawls is offline
#0122 (Nasa Knights)
srawls is an unknown quantity at this point
Send a message via AIM to srawls
Look at section 3.2 of the Robot Rules, entitled "Wiring the Robot Controls," and for a quick reference, look at the electrical diagram for the robot.
Basically, connect the battery to the 120 Amp Circuit Breaker, then connect that to a fuse panel, and connect the robot controller to the fuse panel through a 20 Amp auto-resetting breaker.
Stephen
Unread 14-01-2003, 00:00
Gobiner Gobiner is offline
#0753 (High Desert Droids)
Gobiner is an unknown quantity at this point
Send a message via ICQ to Gobiner Send a message via AIM to Gobiner
It won't hurt anything (except maybe people) to connect anything straight to the battery. If you go through the fuse panel, the voltage drop across any component, motor, whatnot is always twelve volt. Actually, you might hurt the battery if you completely short it, so don't do that. Otherwise, you're safe. Early in the electrical phase, the circuit breaker makes a nice switch to turn motors and such on/off.
0N3 1337 PR0G|24MM1N6 N1NJ4
If you had one thing to be proud about this season... Solon Jhee General Forum 48 25-04-2003 18:10
What is the Craziest thing YOU have done with duck tape Jon K. Chit-Chat 70 07-04-2003 00:20
Swamp thing a swamp ramp? :) GateRunner Chit-Chat 5 02-04-2003 16:25
The only thing I'll miss from nationals: Frozen Carbonated Beverage asher Chit-Chat 22 30-04-2002 18:46
What's the most important thing for new Teams to remember? Brian_Lim General Forum 6 06-01-2002 21:26
