Dose anyone know where I can find the specs for the Servo's that were provided in the kit??
This is the Hitec HS-322 Deluxe Servo with the Hitec/JR/Z Connector.
FEATURES: Three pole motor. One resin bushing. INCLUDES: One Hitec Deluxe Servo with the Hitec/JR/Z Connector with, four 2mm x 15mm phillips head mounting screws, four rubber grommets, four eyelets, one star shaped, one arm, and two arm straight servo horns SPECS: Wire color codes: Black-Ground, Red-Power, Yellow-Signal Operating speed: 0.19 sec @ 60 degrees at 4.8V Torque: 39oz/in (2.8kg cm) Weight: 1.51oz (43g) Length: 1.57" (40mm) Width: 0.78" (20mm) Height: 1.43" (36.5mm) Wire length: 12" (305mm) approximate JXS 7/12/02 ir/kh |
| Q&A Discuss: Are specs available on the new motors/mounts? | CD47-Bot | Extra Discussion | 3 | 15-01-2003 19:39 |
| motor specs? | Gary Dillard | Motors | 0 | 04-01-2003 17:54 |
| bridge specs | archiver | 2001 | 2 | 23-06-2002 22:52 |
| On-board chip spec's | archiver | 2000 | 4 | 23-06-2002 21:55 |
| Motor specs | kmcclary | Off-Season Events | 4 | 26-10-2001 22:41 |
