Go to Post I love the dedication of Robotics kids. :) - Danielle H [more]
Unread 15-01-2003, 10:40
cammie825 cammie825 is offline
#0825 (Maximum Velocity)
cammie825 is an unknown quantity at this point
Send a message via ICQ to cammie825
Joystick
I had a question about the abilities of our joysticks. Is there a way to program the buttons or triggers so that when you continuously hold the trigger the action is performed, and when the trigger is released the action stops?
Unread 15-01-2003, 10:48
D.Viddy's Avatar
D.Viddy D.Viddy is offline
AKA: Dylan Vester
FRC #3176 (Purple Precision)
D.Viddy is an unknown quantity at this point
Of course
It's going to look something like this (note: I use the underscores for indention purposes only, do not include them in your code):
'If port1 trigger is pressed then
If p1_sw_trig = 1 then
_____'Perform Action Here
endif
Or if you wanted it so when you pressed a joy button it would turn an action on, and when you pressed it again, it would do another action then:
'Declare this variable at top of code
action_on VAR byte
_____'Switch from on to off
_____toggle action_on
endif
'If alternate action is specified then
If action_on = 1 then
____'Do action here
else
____'Do another action here
end if
Dylan Vester - (Programmer)
Running a P4 1.8 Ghz
Team 998, We can't win...
how do i control a piston with a joystick Ryan Foley Programming 2 27-05-2003 17:13
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
joystick problem archiver 2000 12 23-06-2002 23:08
switching joystick axis????? team222badbrad Technical Discussion 9 16-01-2002 23:07
