Go to Post Part of Gracious Professionalism is the Professional bit. Doesn't matter if you're a volunteer or a staff member, a failure of this level in the real world would result in getting fired. - [more]
Unread 17-01-2003, 00:01
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
Downloading Code with new Editor
Has anyone had problems downloading code from the new editor to the 2003 controller. About 80% of the time the computer does not find the BS2SX. We have tried swapping the cables, rebooting the computer and power cycling the RC before downloading. Nothing seems to help. It seems to randomly work about 20% of the time. Anyone have any ideas?
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 17-01-2003, 00:20
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
I've only had one opportunity to try to use the new editor with any actual hardware, and it never failed to alert me to the painful fact that it couldn't find a Basic Stamp...
I should start troubleshooting this, but if anyone has any specific solutions, I'd be much grateful, as well.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 17-01-2003, 00:39
Kevin Watson's Avatar
La Caņada High School
FRC #2429
I've seen this with BASIC stamps before. The problem was with the type of RS-232 transceiver the computer had. Some newer computers (especially laptops) have transceivers that don't swing the minimum voltage range of 10 volts that the RS-232 specification specifies. You might try a different (older) computer to get it to work (this is what I did).
-Kevin
Kevin Watson
http://kevin.org
Unread 17-01-2003, 00:48
While I am using a laptop, it is by no means new (75 Mhz 486)
I never had a problem last year. When I first downloaded the new editor, I tried it on a 2001 controller that we use for our prototyping. It did not recognize the controller that I prototyped with all last year and this fall. I figured that the new editor and the old controller were incompatible. The first time I downloaded the 2003 controller from the new editor it worked. Since then it has been 20% success at best
Unread 17-01-2003, 01:10
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
I used to have this problem when I had the 2002 RC tethered... it would never detect the RC properly. The problem seemed to go away when I removed the tether when attempting to upload the program.
The best moments of our lives fall in two categories: those that did happen and those that did not.
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
Impending BASIC Stamp Editor Beta 2 release Greg Ross Programming 9 19-09-2003 06:05
FIRST Editor v1.0 Raven_Writer Programming 0 12-09-2003 16:23
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
Patent source code? Kyle Fenton Chit-Chat 3 20-10-2001 17:53
