Go to Post And let's face it their junk is our robot! - jrgrim12 [more]
Unread 17-01-2003, 15:45
Gui Cavalcanti's Avatar
Gui Cavalcanti Gui Cavalcanti is offline
Robogeek
Gui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to all
Send a message via AIM to Gui Cavalcanti
Screw jack system
My team is considering building a vertical dual-screw mechanism. We are considering two ways to power it - the first way involves a window motor powering each screw independently. I'm worried that if the motors are not completely identical, minute differences in speed would cause the screws to bind, taking us out of competition.
The other option is to chain the two motors together and power the screws with a horizontal chain. My team's mentor is worried that, because the chain is horizontal, it might run the risk of jumping off the sprockets during competition.
Any advice?
Gui Cavalcanti
All-Purpose College Mentor with a Mechanical Specialty
Franklin W. Olin College of Engineering, Class of 2008
Unread 17-01-2003, 17:26
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
Just make sure you have enough teeth engaged and that you consider an idler or adjustment technique to 1) help you at installation and 2) can take up the slack when changing direction
Unread 17-01-2003, 17:31
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
For something like this you could probably also use timing belts/pulley which would reduce weight as well.
Unread 17-01-2003, 22:55
jrgrim12 jrgrim12 is offline
Let's have fun!
#1022 (ArcherGEeks)
jrgrim12 will become famous soon enough
Send a message via AIM to jrgrim12
Could you use two guide pins and one screw? You could two pieces of drill rod and use those to guide the shuttle and use one screw two move the shuttle.
James Grim
www.youthbotin.org
www.ztspeedandfab.com
Unread 18-01-2003, 18:17
GUI I believe this is one of the better ways to accomplish your task. A single timing belt running to both lead screws and the drive motor. More or less the belt would form a triangle with the lead screws at two corners and the motor at the third.
A second alternative, if space allows, is the drive motor with a sprocket, midway between the two screws, driving sprockets attached to the screws. (visualize three ring circus)
Unread 18-01-2003, 23:57
Don Reid Don Reid is offline
Don Reid will become famous soon enough
Limit switches
If you have to use two motors, and you can get an arm from one moving piece to the other, you can do this.
Put two limit switches (micro switches,...) on one piece so that the arm hits one or the other if the two sides are not even (level). Then have the software slow down the motor that is ahead.
Make the arm tip flexible to avoid damage if there is an error
Don Reid
Unread 19-01-2003, 13:07
Switches picture
Here is a drawing of what I was talkign about in my previous reply (thanks to the admins for enableing PNG attachments so quickly).
Don Reid
Need a FIRST Robotics control system kershawrobotics General Forum 3 07-07-2003 09:49
Scoring system for 2004? DougHogg General Forum 11 16-04-2003 20:57
what's your most important drive train advice? Ken Leung Technical Discussion 42 07-01-2003 09:58
control system worth more than $500 archiver 2001 8 24-06-2002 02:00
New Innovation FIRST control system and the dashboard archiver 2000 0 23-06-2002 22:15
