CG of Bins
Hey, has anyone modelled and calculated or measured the specific CG (Center of Gravity) of the Sterilite Bins? Looking for height of CG from the bottom of the bin.
Thanks in advance. |
The easiest way I know to do this is to ballance the bins on 2 different edges. The CG, when ballanced, will be directly above the ballance point. Doing this on two edges will give you two lines that intersect at the CG.
I don't have a bin handy, but it shouldn't take long to do this. |
One thing I've tried before is to attach 3 strings to the outside edges of the object you are weighing. Keep adjusting the lengths of the string until all 3 have been pulled taut, and hang a weight from the point at which they meet. There's the center of gravity for that plane.
I've only seen it done once, and it was a tedious effort. Does anyone else know of a better method? Namely for 130 pound robots. |
First, find a function to express the density of the box. The x-coordinate of the center is given by dividing the integral of x times the function by the integral of the function. The y-coordinate is the integral of 1/2 the function squared divided by the integral of the function.
You can also do this by sliding pipes under your robot, starting from the edges and moving them to the center. The pipe with the least force always moves the easiest and you always end with the pipes under the CG of the robot. A method used for cars is to suspend your robot and swing it like a pendulum. The period of the pendulum can be used to calculate the CG. Another method used for cars is to put scales under all four wheels and then elevate the front and measure the weight transfer to the rear, and vice versa. |
| What do you YOU use your bins for? | AlbertW | General Forum | 40 | 13-04-2003 04:18 |
| Falling bins are like dice | GregT | General Forum | 18 | 12-01-2003 00:56 |
| robot touching a stack of bins | carlye | Rules/Strategy | 20 | 11-01-2003 02:13 |
| tipped bins | cbudrecki | Rules/Strategy | 25 | 07-01-2003 23:12 |
| How will the bins face on the ramp? | Jacqui Sutton | Rules/Strategy | 1 | 07-01-2003 08:48 |
