Go to Post This could be interesting...rednecks of FIRST unite for duct tape - amos229 [more]
Unread 20-01-2003, 21:22
David Bryan David Bryan is offline
#0818 (Steel Armadillo)
David Bryan is an unknown quantity at this point
Unhappy The angle of going up the Ramp
Yaw sensors: Can we use it to tell us if the robot is going directly up
>the ramp? Suppose our robot does not touch the bottom of the ramp at 0
>degrees (which would allow it to go straight up the ramp), Suppose it
>touched the bottom of the ramp at 45 degrees, would the yaw sensor give us
>the math to tell us what angle we were at?
Does anybody know of a device that will give us this input?
It would be like a level in two directions setting limit switches. Or maybe we could make something out of a level and potentiometers????
Unread 21-01-2003, 09:05
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
You could use the yaw rate sensor (aka, the Gyro) to do this. It would tell you when you were changing angles, like at the bottom and top of the ramp. On the ramp itself, the gyro would return a neutral (127) response.
Jeff Waegelin
Unread 21-01-2003, 20:56
n[ate]vw's Avatar
n[ate]vw n[ate]vw is offline
#0933 (Adler Attack)
n[ate]vw is an unknown quantity at this point
Send a message via AIM to n[ate]vw
I take it you are talking about left/right angle up the ramp. You could use a gyro to find your angle relative to your starting position, but its accuracy is not guaranteed. There are many threads about gyros / yaw rate sensors / integrating them that you can search for for more info.
Adler Attack #933 -- Trigos
PBASIC ARCTAN function Greg Ross Programming 14 11-05-2003 12:28
modifications for easily traversing the ramp Solace General Forum 2 22-01-2003 20:50
blocking the ramp Jacqui Sutton General Forum 3 07-01-2003 09:02
Pulling robot off ramp legal? archiver 2000 2 24-06-2002 00:14
Technical question about ramp balancing archiver 2001 5 23-06-2002 22:29
