Go to Post Just be nice. It works better in the long run. - Libby K [more]
Unread 20-01-2003, 22:57
Jeff Sharpe Jeff Sharpe is offline
#0473 (Montana State Robotics)
Jeff Sharpe is on a distinguished road
drill gearbox schematic?
I seem to remember seeing reference to a schematic for the drill gearbox, but couldn't find it searching past threads. Does anyone have an idea for a quick link? Our drill is grinding out of gear and I remember a couple folks playing with it disassembled, and thought it wise to have the drawings (if available) before taking it apart to check it out. Thanks! J#
Unread 20-01-2003, 23:51
Umm Errr...
those arn't for the drill gearbox.
1139 Alumni
Unread 20-01-2003, 23:56
srjjs's Avatar
srjjs srjjs is offline
Slightly Rehabilitated
AKA: Larry Wang
#0840 (Aragon Robotics Team)
srjjs will become famous soon enough
Send a message via AIM to srjjs
I believe that "drill gearbox" means the thing attached to the end of the motor, not the mount for the helical gears.
I would check the website of the company that makes the motors, or look around for an inventor model of it.
SVR Imagery Award
SVR Semifinalists with 473 and 687
RIP Andrew Dang
3/22/2004
Unread 21-01-2003, 00:18
Suneet Suneet is offline
Physicist-In-Training
None #0599 (RoboDox)
Suneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to behold
Send a message via ICQ to Suneet Send a message via AIM to Suneet
You can get accurate external demensions off the Inventor files posted by autodesk. At least, I hope they're accurate... They better be, as I made the specs for our dual-motor gear box using them. Anyone have any idea?
The file is "Drill Motor.zip" here: https://folders.buzzsaw.com/2003FRC/...20files?Public
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
A new record for breaking a drill motor ZacharyD Technical Discussion 23 16-01-2003 16:58
Specs for drill motor gearbox? archiver 2000 4 23-06-2002 22:36
