Go to Post Why is it considered shameful to do the smart thing? As the saying goes, "I don't make the rules, I just live by them." - Chris Hibner [more]
Unread 24-01-2003, 01:29
Noah's Avatar
Noah Noah is offline
Code Monkey
#0861 (The Gondobots)
Noah has a spectacular aura aboutNoah has a spectacular aura about
Send a message via AIM to Noah
Lightbulb Hints For Rookie Programmers
Thought I would lay down a couple guidelines:
1) Never program when you have less than 6 hours of sleep in the past 24. IT DOESN'T WORK (Without a lot of coffee)
2) Always initialize your PWM outputs to 127. If you don't it will default to 0. (0 is full reverse. I forgot to initialize my motor outputs. We turned on the robot, and it went backwards full speed and almost bashed one of our engineers in the shins... )
3) Don't forget to increase those counters! (Well... I forgot this crucial step in one loop in our autonomous program... our robot was spinning in a circle for about five minutes)
Ok, they're obvious, I know... just thought I'd share them. Anyone got any others to add?
"It's broken? NOOAAHH!!! This is your doing, isn't it!"
"We can fix it in the software!"
"It's a BROKEN GEAR!"
Unread 24-01-2003, 01:34
Umm Errr...
sleep.... programmers don't need sleep. I have fallen asleep coding before. Thats when u stop.
1139 Alumni
Unread 24-01-2003, 01:42
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Re: Hints For Rookie Programmers
In that case, I don't think I'd ever be able to do any coding, much less be able to code during the build season. Sleep is for the weak!
Anyway, some other good ones:
*Always make sure your CON stuff matches your SERIN.
*Always test code before uploading it to the robot.
*Never let an ME person touch the laptop.
*~ is not (no pun intended) the same as NOT.
Unread 24-01-2003, 01:45
Noah's Avatar
Code Monkey
While the code I write at 4:00 am is a great deal more efficient and interesting than anything I write while under the influence of sleep, No-one (Myself included) can ever reason out just what I did. I almost always end up rewriting such code (In a signifigantly more obvious way) later. In the end, I would have saved my own time by sleeping when I was programming and programming when I was sleeping. (Of course, I haven't slept recently as I write this, so perhaps I'm a bit of a hypocrite). Of course, when I'm awake I also don't forget to increment my counters and such...
Granted, that was when I had gone for 36 hours without sleep, but even so, that was pathetic. ::Bangs head against wall for miserable failures::
Unread 24-01-2003, 02:01
You mean like this line taken directly from RoboEmu (comment included)?
*(unsigned int *)((int)out+i*sizeof(unsigned int))=result; //have fun figuring out this one
If this line ever fails, I'm going to have to delete it (and most of the surrounding function) and start over. It seemed like such a good idea at the time...
Unread 24-01-2003, 22:28
Cipher X's Avatar
Cipher X Cipher X is offline
no team (Former SigmaC@t Member)
Cipher X is an unknown quantity at this point
Send a message via AIM to Cipher X
Exclamation Freakin DEBUGS!!
All i got to say is that DONT use too many debug statements { I dont belive they tell you this in the manual}
I was writing code for a neighboring team {947} and they were using a potentionmeter and i was just testing it out seeing what values it was outputting. But on top of that i just wanted to make sure that i was getting all teh right inputs and i was giving out all the right outputs. By the end of it i wound up with like 13 {some stupid number} DEBUG statements. Now all of a sudden the Revolving light turn off and on and all the motors work and then doesnt work and then works etc.. Now i took out all the Debug statements and everything worked fine. I think its because the timing for the DEBUG statements is too long and maybe too many of them makes the whole loop go so much slower that the controller looses its timing i guess. only thing i could think off. But remember try not to use more than like 10 DEBUG statements Max at once. I dont know if PBasic 2.5 fixes this but i am pretty sure it doesnt i have tried it out yet.
Cipher X
"Whatever you do will be insignificant, but it is very important that you do it."
-Mahatma Gandhi
Unread 25-01-2003, 05:30
Jferrante Jferrante is offline
Jferrante is an unknown quantity at this point
Send a message via AIM to Jferrante Send a message via Yahoo to Jferrante
I am afraid that despite the complaints of the useless posts I must add in the classic line that is all to needed in this thread.
What is sleep and where can I download it?
Unread 25-01-2003, 06:25
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
I've been looking for a cracked copy for weeks... No luck yet. I guess I'll stay up and keep searching...
As for programming tips, keep a copy of the Basic Stamp Manual handy. If you're ever unsure of the syntax of a command, you can alway lookup it, hyuk hyuk.
If you ever REALLY need to stay awake (like, life threatening emergency, or just for fun) Sobe Adrenaline Rush will most likely do it for you, and it tastes good, too.
Oh, listen to music that won't agitate or otherwise negatively affect you. You're going to get pissed off at your code enough as it is, without sub-par music blasting in your ears. Pink Floyd, The Beatles, Phish, Tool... whatever you're comfortable with.
One last thing. The light of your computer's monitor is ALWAYS enough light to work under.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 25-01-2003, 07:39
Dave... Dave... is offline
#0005 (Robocards)
Dave... will become famous soon enough
I guess I'm in trouble since I'm an ME and the programmer for the past three years.
Did a pretty good job of winging it though, eh? Never crashed the robot into my own shin (or anyone else's, but came close)
Unread 26-01-2003, 16:33
Curtis Williams Curtis Williams is offline
#0588 (Team 588)
Curtis Williams is on a distinguished road
Send a message via ICQ to Curtis Williams Send a message via AIM to Curtis Williams Send a message via MSN to Curtis Williams Send a message via Yahoo to Curtis Williams
Crashing into a shin? We should be so lucky. The MEs didn't listen when I told them to back away during testing. One got smacked in the jaw with a van door motor when the robot went full reverse.
Anyway, sleep is the absolute worse thing you can do to yourself while programming. After sleep you are too energetic to sit down and code. You have to stay on the edge where you are too sleepy to run outside, but awake enough to code. Every time you sleep you are loosing the 8 hours taken by sleep, and 16 hours because your energy level is too high. If you keep this "good sleep" up you will never have good programming time. You must stay awake, and when you hit the edge, you must stay there. Caffeine helps.
Unread 26-01-2003, 18:43
Raven_Writer's Avatar
Raven_Writer Raven_Writer is offline
2004 Detroit & Pittsburgh Winners
AKA: Eric Hansen
FRC #0005 (RoboCards)
Raven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really nice
Send a message via ICQ to Raven_Writer Send a message via AIM to Raven_Writer Send a message via MSN to Raven_Writer Send a message via Yahoo to Raven_Writer
lol. Also came close to crashing an old robot into the ground, and running into a few members (the good times).
AIM: wisprmylastbreth
EMail: nightskywriter@gmail.com
Y!: synsoflife
"ai yoru ga" -- "Love the nights"
Unread 26-01-2003, 21:55
EvanG EvanG is offline
Alumni fly-tackle bait
None #0177 (Bobcat Robotics)
EvanG will become famous soon enoughEvanG will become famous soon enough
As a programmer, i can say i've found that having a close to hand set of switches with a kill switch is effective for when your bot decides to go AWOL... until the kill switch solder breaks.
Unread 26-01-2003, 23:36
Anthony Kesich's Avatar
Anthony Kesich Anthony Kesich is offline
Programmer Turned Engineer
AKA: SonKenshin
#1097 (Site 3 Engineernig)
Anthony Kesich has a spectacular aura aboutAnthony Kesich has a spectacular aura about
Send a message via AIM to Anthony Kesich
Red face sleep
Its true, i tell ya. Every week, we have at least one 12-hour meeting, and for at least the first 8 hours i do almost no programming, unless we need it desperately (I'm normally found trying to pose as a grease monkey ). But for those final 3 hours or so, i get [b]everything[b] done. I used to think it was just me, but it seems i'm wrong.
-Anthony
C is screwing up my English--I'm ending all my sentences in semi-colons;
Horray for most things! -George Carlin
"Sure, I'll play rugby. Besides, I have a lot of experience running from really big guys who want to cream me." -Me, Freshman year
Unread 26-01-2003, 23:52
redbeard0531 redbeard0531 is offline
#0686 (Bovine Intervention)
redbeard0531 is an unknown quantity at this point
Send a message via AIM to redbeard0531
Re: sleep
Originally posted by Anthony Kesich
[b]Its true, i tell ya. Every week, we have at least one 12-hour meeting, and for at least the first 8 hours i do almost no programming, unless we need it desperately (I'm normally found trying to pose as a grease monkey ). But for those final 3 hours or so, i get [b]everything done. I used to think it was just me, but it seems i'm wrong.
-Anthony
You must be sleep deprived
if 8 + 3 = 12 then GOSUB HelpMe
HelpMe:
Grade = Grade MAX 2 ' sends me back to second grade
Return
I must say that 8p - 2a are my best programming hours.
btw, if you have a food lion neer you, dr perkey and mountain loin are cheap, great tasting, and loaded with caffine and sugar!
Unread 27-01-2003, 00:00
AKA: SonKenshin
im both fearing and looking forward to the final weekend. WE have a 5 day weekend at my school that weekend cuz of combining holidays and teacher meetings, so either ill rock and programming and make something godly or i will go into a coma from lack of sleep (or food if i do progam too intensly )
-Anthony
Calling all PHP/ASP programmers! blueWarrior FIRST-related Organizations 15 27-01-2004 13:24
My hints and guess on the Game in 2004! Elgin Clock Rumor Mill 116 09-01-2004 13:30
The Grand FIRST team.. programmers and others needed randomperson Programming 0 31-05-2003 23:46
PIC Programmers seanwitte Electrical 8 18-04-2003 17:04
Hints @ Kickoff Broadcast Nate Smith General Forum 13 05-01-2002 10:14
