Go to Post So if you were a rookie team in this division what would you do? Watch.Experience.Learn. - dodar [more]
Unread 27-01-2003, 09:50
geo's Avatar
geo geo is offline
A Nuke Would Do The Job!
FRC #0865 (WARP 7)
geo is a jewel in the roughgeo is a jewel in the roughgeo is a jewel in the roughgeo is a jewel in the rough
Unhappy trouble with assembling FESTO valve
Hi. I am just wondering how to assemble that FESTO valve??????
a digram will be great. Thanks
2006 Greater Toronto Regional Winner!(with 1114 & 1503)
2002 Canadian Regional Winner!(with 610 & 781, our rookie year )
Unread 27-01-2003, 10:04
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
i cant remeber right off hand but isn't there a sheet of instructions or a diagram with it?
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 27-01-2003, 10:33
geo's Avatar
geo geo is offline
FRC #0865 (WARP 7)
Tere is no sheet of instructions in our kit. I had one from last year but I lost it
Unread 27-01-2003, 10:56
RebAl's Avatar
RebAl RebAl is offline
ISee It When I Believe It
None #0329 (The R.A.I.D.)
RebAl will become famous soon enough
Send a message via ICQ to RebAl Send a message via AIM to RebAl
They are on the little baggy with the plastic o-ring/led seal in it
Unread 27-01-2003, 11:12
geo's Avatar
geo geo is offline
FRC #0865 (WARP 7)
I checked that too. I can't find anything
Unread 28-01-2003, 00:20
jon virgi jon virgi is offline
#1191 (Eagles)
jon virgi is an unknown quantity at this point
Send a message via AIM to jon virgi
here you guys go, it shows detailed pictures and instructions on how to put the valve together.
http://www.festo.com/INetDomino/file...TValveAssy.pdf
Keystone Oaks Robotics Team President / Webmaster / Lead Pneumatics designer / Lead electrical........
Unread 28-01-2003, 09:06
geo's Avatar
geo geo is offline
FRC #0865 (WARP 7)
Thanks a lot
Unread 28-01-2003, 09:09
#1191 (Eagles)
no problem
Unread 29-01-2003, 08:23
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
Hey everyone,
We are having some issues with our Festo too, and I didn't feel like starting a whole new thread for it.
We assembled it to specifications, but every time we run it, and switch it, it doesn't change the air flow. We've tried it with both manual turned on and off, we've checked our wiring, and heck, we even put an extra bolt onto the electromagnetic controller to see if it would pull it in, and it did.
Anyway, we aren't too sure what's wrong w/ the thing, and we need to have it running pretty soon. Right now were stepping in one of our SMC's as a makeshift single until we can fix it.
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 29-01-2003, 08:28
sorry about the confusion i guesse there isn't an instruction sheet...someone had printed out that PDF and stuck it in with ours so i thought it just came with it.
Unread 30-01-2003, 00:00
Scott358 Scott358 is offline
Engineer/Mentor
AKA: Scott5736
FRC #5736 (Kingsmen)
Scott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really nice
Smile See first thread in this section...
The first thread in the Pneumatics section has a link to the assembly info for the Festo valve assembly.
If techincal questions arise, the number is:
1-800-99-FESTO (1-800-993-3786)
Hope this helps...
Scott
Unread 30-01-2003, 00:22
Sachiel7's Avatar
AKA: Shayne Helms
We haven't had any issues assembling the vavle, it's not operating correctly.
-=Sachiel7=-
Unread 01-02-2003, 09:03
If it's not working and you're using 60 psi on it, contact the manufacturer or First.
Be aware that these valves use an electrically operated pilot valve, which switches the air coming into the middle port, to operate the main valve. It will not operate the main valve on lung pressure. (Years ago, our first year, our valves "wouldn't work".)
They must be connected to compressor-stored air to work
Unread 01-02-2003, 20:57
mechsoph mechsoph is offline
mechsoph is an unknown quantity at this point
Send a message via AIM to mechsoph
We're having trouble too
We're having trouble with our FESTO valve too. We assembled it as per the instructions provided by Festo and connected it to the 60 psi regulated output from air tanks and compressor. The valve would not change state when we applied a voltage. It would change states when we manually turned the screw on the bottom. We substituted and SMC double acting solenoid valve which worked correctly; however, we need to use all three valves. If any of you have any insight, we'd really appreciate it.
Unread 02-02-2003, 02:00
Sachiel7's Avatar
AKA: Shayne Helms
We got ours working now...
Not 100% sure how we got it going, but I think it might've been that we were using our own lungs for one test time...I think...
Anyway, It works now. Just don't ask me how.
-=Sachiel7=-
Anyone else having trouble keeping up with work? D. Gregory General Forum 36 28-03-2004 16:55
Festo valve.... why wont it work? CHSguard72 Pneumatics 3 08-02-2003 19:07
Link to Festo Valve Assembly Info Scott358 Pneumatics 0 04-01-2003 17:17
Festo Valve Gary Bonner Pneumatics 2 26-02-2002 17:48
What is the wiring for the FESTO valve? Nuts4FIRST Technical Discussion 4 12-02-2002 17:14
