Go to Post Not everything has to be cashed in or has to have instant recognition. Sometimes being a part of a program of value and opportunity is enough. And, what you put into the program is what you get out of it. - JaneYoung [more]
Unread 27-01-2003, 11:16
REVving up for a new season
FRC #2848 (All-sparks)
the E-Stop
See Team Update #7. The driver may not use the e-stop button for any reason other than to stop the robot. The robot will not be able to be restarted until the Autonomous period is over.
I take this to belive that if people don't like they way that the autonomous mode is going they can stop the robot for almost no reason........which means we will be seeing alot of "emergency" stops??
Unread 27-01-2003, 11:52
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
Sounds like a smart move. E-Stop, however yes, the E means emergency, but it's there so for safety. What if the program says.. go left, then up the ramp. But they are on the left side (needing to go right) and forgot to flip their switch the right way. That's not an emergency, but it can cost them the match if they drive the wrong way and get stuck on the side barrier.
It doesn't take much to disable a bot if it's caught on the side, we noticed this last year in the finals at GLR. After Truck Town blew a motor, we went with us (247) and 274. 274 had a small piece of sheet metal get jammed on the barrier when going for balls. That put us against 2 powerful teams, and thus a loss.
Unread 27-01-2003, 13:06
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
the E-Stop button does not disable you for the match!
last year, pushing it down disabled you. to re-enable yourself, you would twist the button, and it would pop back up. then, you could drive around again. useful for almost nothing last year, very important this year.
if you hit the E-Stop button, your robot light shuts off, and your player station light blinks (i believe). when you twist and release the E-Stop button, both should come on solid again.
keep in mind, the referees will disable you if you aren't quick enough to do it yourself, and from what i've seen, they don't re-enable you.
AIM --> Woloi
Email --> ian@woloschin.com
Unread 04-02-2003, 10:25
Lee Lee is offline
FRC #0343 (Metal In Motion)
Lee is on a distinguished road
According to update #9, if a team member presses the E-Stop button, the autonomous period is stopped and driver operated play is suspended for 30 seconds. According to a FIRST question I posed, if the referee stops the robot during autonomous period, AND, if there is no evidence of further damage to the field, etc, the robot will restart during driver operated mode with no delay. This means using the E-Stop button for convenience will definitely hurt your match.
Unread 10-03-2003, 15:54
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
How did this work out at the regionals? Were people using the buttons to manage Auto mode? Did the refs dissable you for 15 seconds into manual? Or were you able to pop it into manual as soon as you could reach the button (jump 3' to controls, twist, pull and go)? Seems like the ruling switched from it's earlier 30 second penalty..???
Unread 13-03-2003, 13:23
At the BAE Regional we (358) used the E-Stop several times during the practice rounds on Thursday during autonomous mode to stop the robot from shoving against a wall for the entire 15 sec. The E-Stop kept us from driving for 30 sec., so the autonomous period was long over by the time we got moving again.
Unread 13-03-2003, 18:42
David Lantz's Avatar
David Lantz David Lantz is offline
None #0118
David Lantz will become famous soon enough
Team 45 also used their E-stop several times throughout the practice sessions and they payed for it with a 30 sec time out. We personally never used it because we knew what the consequenses of doing that during a quallifying round could be.
Those who say it cannot be done should not stand in the way of those who are doing it.
-Someone Famous
Unread 13-03-2003, 18:59
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
At Sac many teams disabled their autonomy in practice. I can remember a single instance in which this happened t=during real play though.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 10-04-2003, 13:35
Billius Billius is offline
#0898 (Team Desert Storm)
Billius is an unknown quantity at this point
I only used the E-Stop in a practice round. Our auton program went crazy and attacked the spectators (seriously, it LEFT THE PLAYING FIELD, would have been cooler if it went after the judges, lol j/k). However, since our robot coasts very wheel, it was a good couple more seconds before it actually stopped.
Anyway, back to the point of this thread, make sure that you twist the E-Stop button all the way in and then make sure that you release it by twisting it the other direction (there are arrows on the button). If you don't release the button, you can be disabled for the whole match.
"Shop smart, shop S-mart"
Unread 10-04-2003, 22:26
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
You do not need to twist it down, just slap it.
Twist to release.
Wetzel
Safety is easy.
Unread 13-04-2003, 22:13
jonathan lall's Avatar
jonathan lall jonathan lall is offline
FRC #2505 (The Electric Sheep; FRC #0188 alumnus)
jonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond repute
Send a message via MSN to jonathan lall
Yeah... in one match in WMR, the bracket for our radio fell on the E-stop, and disabled us. It doesn't take much to kill your robot...
Can you stop a pneumatic pump at half shaft mjt902 Pneumatics 16 06-02-2003 11:58
everyone stop by at NYC!!! archiver 2001 8 24-06-2002 01:57
Where do the stop buttons go??? archiver 2001 0 24-06-2002 00:35
stop buttons at championships Jay5780 Rumor Mill 20 20-04-2002 11:16
Pact of Secrecy (Stop Telling US!) Joe Matt Rules/Strategy 17 30-01-2002 01:02
