Go to Post There MUST BE room for mistakes. That’s one of the best ways to learn. - Ken Leung [more]
Unread 01-02-2003, 14:44
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
Image Discuss: Wheels- you want wheels - more from team 25
Unread 01-02-2003, 14:46
Devil's Kid's Avatar
Devil's Kid Devil's Kid is offline
#0912 (IRON Lyons)
Devil's Kid is an unknown quantity at this point
Lathing those wheels
We tried to lathe the 9" skyway wheel which i think is the one you have but we couldn't do it because the rubber is too soft and all that happens is it ripps off... i am wondering how you guys got around that or specifically which tool did you use?
Unread 02-02-2003, 10:39
Wayne C.'s Avatar Unsung FIRST Hero
Wayne C. Wayne C. is offline
hey- I think we did pretty good?
FRC #0025 (Raider Robotix)
Wayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond repute
you use a grinding tool in the lathe and it wears it down. A cutter just grabs the rubber and tears out chunks. It will take a while for each wheel but we like it.
WC
you want that robot to do what?
Raider Robotix- www.raiderrobotix.org
Unread 07-09-2003, 01:01
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
We used a standard metal cutter in the metal lathe and it worked GREAT! You just have to take only a little at a time and use a high speed and be sure to use auto feed. This will provide a nicely textured flat surface.
Unread 07-09-2003, 01:42
jonathan lall's Avatar
jonathan lall jonathan lall is offline
FRC #2505 (The Electric Sheep; FRC #0188 alumnus)
jonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond repute
Send a message via MSN to jonathan lall
Re: Lathing those wheels
Yeah, I noticed that and I think I mentioned them to you guys when I stopped by your pit at the CR.
Metal lathes are great. Most standard metal cutting blades are excellent for non-metal soft surfaces such as rubber, plastic, and wood when the lathe is run at a non-low speed and small amounts are taken off at a time (at a uniform pace, usually accomplished by the auto feeder). As long as you keep the blades sharp and use the lathe with good sense, it'll do the job quite well.
Unread 07-09-2003, 14:42
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
We simply used a belt sander to remove the material. We then spun the wheel to see if we removed the right amount of material.
You can also drive the robot around outside on rough concrete and have the same effect, but you risk getting all sorts of other junk up inside the robot.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 07-09-2003, 15:42
If you don't have a lathe you can perhaps find a way to put it in a drill press and use a file. You would need a 5/8" or larger chuck or an axle shaft that is turned down, on a lathe. Hrmm.
Unread 07-09-2003, 16:02
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
In the past we put the bot up off of its wheels and had someone with a piece of sandpaper and a block at each wheel and ran the drive train. Its a good way to test the drive train too.
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 07-09-2003, 16:06
Ashley Weed Ashley Weed is offline
Rookie Year: 1995
Ashley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond repute
We were also successful at cutting our wheels... and they were withstanding normal usage. However, we still ran into problems on the metal ramp where it just sliced through them. Although, by the pile of rubber underneath the ramps, I would say many others had the same experience.
Unread 07-09-2003, 20:18
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
Last year, we let the metal grate do the work for us. Every match we got better and better traction as the wheels wore down how the grate 'wanted' them to wear. some smooth parts, some notches, always pretty evenly round though. In future years, we probably can't do that same method... I'd suggest like A. Rudolph said, thats what 247 did for OCCRA last year.
Unread 07-09-2003, 20:33
One more way you could get fairly even wear for a better traction profile is to tie the robot to a stationary object and run it while on an abrasive surface like a sidewalk. Be sure to cool the motors though.
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
More 'Best' Robots (a well thought list) archiver 2000 2 23-06-2002 23:11
