Go to Post ...and leave your bumpers at home. - Andy Grady [more]
Unread 03-02-2003, 09:41
Caleb Fulton's Avatar
Caleb Fulton Caleb Fulton is offline
Z = Z^2 + C ......WHEEEE!
AKA: aXvXiA
#0461 (West Side Boiler Invasion)
Caleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura about
Send a message via AIM to Caleb Fulton
Ribbon Cables for Digital Input
Is it okay to use ribbon cables for transferring digital inputs from a screw-down block to the RC? The wiring diagram says that you should use 24g/2 or 3 conductor wire, but wouldn't ribbon cables do about the same thing?
Unread 03-02-2003, 10:03
Rule C8 specifically allows ribbon cable for the digital and analog inputs.
Unread 03-02-2003, 10:22
AKA: aXvXiA
Thanks
Unread 04-02-2003, 11:21
Mike Yan Mike Yan is offline
Mike Yan is an unknown quantity at this point
Send a message via MSN to Mike Yan
Would you be able to use a normal printer cable with the female end cut off and have the wire soldered to a breadboard or some other type of PCB?
Unread 06-02-2003, 01:50
Jay Lundy Jay Lundy is offline
Programmer/Driver 2001-2004
Jay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to all
I'm not sure about the breadboard, but unless the rules have changed (which I don't think they have), cutting standard parallel port cables is legal and used quite often.
Unread 06-02-2003, 08:39
FRC Key Volunteer Trainer
AKA: CrazyNate
One thing to keep in mind is to make sure that you use a straight 25 pin, 25-conductor cable, and not a standard printer cable. I'm helping out a few teams in the area, and we tried using a printer cable last night to wire up a mockup of some digital input switches on the RC, and when we took the plastic shield off of the solder cup, we realized that the last few pins were all bridged together. Of course, with the pin arrangement used on the RC, this would not allow for use of all digital inputs, and may even have the possibility to damage the RC.
Nate Smith
nsmith@smythsoft.com
2.5 is alive !!!! (input ! .. more input ! ) Lloyd Burns Programming 2 14-01-2003 19:15
