Go to Post I can't believe I let build season distract me from the fact that iHop had unlimited pancakes for a few weeks. - IronicDeadBird [more]
Unread 03-02-2003, 17:21
Fares Fares is offline
#1009 (Vikings)
Fares is an unknown quantity at this point
My sensors don't work
I tried installing the sensors on the EDU and test them out, but the coding doesn't seem to be working
this is what i have:
if c_sensor1=1 then c_p1_y=1
what's wrong with this code if it keeps telling me that it expects a label
Unread 03-02-2003, 17:41
DanL DanL is offline
Crusty Mentor
FRC #0097
DanL is just really niceDanL is just really niceDanL is just really niceDanL is just really niceDanL is just really nice
Send a message via AIM to DanL
try using just 'sensor1' and 'p1_y'
And also, it seems like you're trying to make the robot go forward when the sensor is active. Since p1_y is a analogue input/output, it goes from 0 to 254 (note: a common mistake for rookies - including us last year - is thinking that PWM outputs go up to 255. Although TECHNICALLY right (analogue-wise), it's a, uh, how do I put this... *bright flashing red lights*<b>bad</b> thing to output that). Anyways, if you're outputing p1_y to a PWM port, make it equal to 254.
Dan L
Team 97 Mentor
Software Engineer, Vecna Technologies
Unread 03-02-2003, 18:26
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Re: My sensors don't work
A couple of problems: Both c_sensor1 and c_p1_y are CONSTANTS used in initialization to set up communications with the master microprocessor. You're not going to be able to SET c_p1_y. You should use if sensor1=1 then p1_y=1 as SuperDanman suggested.
Also, since you are using PBASIC v2.5 syntax (if ... then ... statement) rather than v2.0 (if ... then ... label), you need to enable 2.5 syntax by including a '{$PBASIC 2.5} directive. (If 2.5 syntax had been enabled, the error message would have said: "Expected a label, variable, or instruction" instead of "Expected a label".)
Robotics Tournament at Sensors Expo & Conference Kyle Fenton Off-Season Events 4 04-05-2003 12:15
Optical sensors with EduBot Gui Cavalcanti Robotics Education and Curriculum 5 02-03-2003 10:05
Q&A Discuss: Optical sensors with EduBot CD47-Bot Extra Discussion 2 01-03-2003 18:37
Q&A Discuss: optical sensors CD47-Bot Extra Discussion 0 15-02-2003 22:58
Robogui ! sensors don't work Fares Programming 2 07-01-2003 16:31
