Go to Post "For once, the cake is NOT a lie." The cake claims liar's paradox. :p - JesseK [more]
Unread 08-02-2003, 12:28
CHSguard72 CHSguard72 is offline
CHSguard72 is an unknown quantity at this point
Send a message via AIM to CHSguard72
Question Festo valve.... why wont it work?
How do you connect up the Festo sylenoid? There are two + or - 12V wires, and a ground wire, but any combination i hook up to my relay wont work correctly. How do I hook it up to a relay (digital)?
Unread 08-02-2003, 14:03
Chubtoad's Avatar
Chubtoad Chubtoad is offline
I'm a weirdo.
#0271 (Mechanical Marauders)
Chubtoad is an unknown quantity at this point
Send a message via AIM to Chubtoad
You hook up the ground to the ground of the robot, not to the relay, then you put the two wires on the relay, which one doesn't really matter, when you push the button to activate it, you'll have to hold it down, unless you alter the programming to make it like a double solenoid works. If that isn't working maybe you put it together wrong, search the forums and you'll find a link to the pdf of how to put it together
a matter of fact I have it on my server Festo Valve Assembly
2003 - GM Industrial Design Award @ SBPLI Regional
My Site!
Unread 08-02-2003, 18:48
The solenoids also need a minimum pressure in order to activate. Are you running the solenoid in a fully (or mostly) charged system?
Also, does it activate when you press the manual button on it?
Unread 08-02-2003, 19:07
RebAl's Avatar
RebAl RebAl is offline
ISee It When I Believe It
None #0329 (The R.A.I.D.)
RebAl will become famous soon enough
Send a message via ICQ to RebAl Send a message via AIM to RebAl
DO NOT GROUND IT!!!! It does not reverse, it is only on or off so you only need the 2 pins that are | | not the _ one , one of the | are + and the other -, this is what that led gasket was for
Problems of the mind... effecting work Gadget470 Chit-Chat 20 18-11-2003 11:56
Q&A Discuss: FESTO Help ASAP!!!! CD47-Bot Extra Discussion 3 16-02-2003 10:55
trouble with assembling FESTO valve geo Pneumatics 15 02-02-2003 09:28
Festo Valve Gary Bonner Pneumatics 2 26-02-2002 17:48
What is the wiring for the FESTO valve? Nuts4FIRST Technical Discussion 4 12-02-2002 17:14
