Making a Dongle - Pin 1 help
Hey-o.... I'm trying to make a dongle for our system.
Joe Johnson's dongle whitepaper shows the Disable pin and pin 1 being switched to ground (with the more-channels pin permanently shorted). An LED is lit up through Pin 1. IFI doesn't list anything about Pin 1. I'm assuming that Joe found out Pin 1 supplied an output voltage of some amount, and so he used that to power the LED. But, that dongle whitepaper is a few year(s?) old. So, my question is this: does pin 1 on the competition port still supply an output voltage that you can use to light up an LED? |
I would assume so. Wasn't it working?
[edit]Put a voltmeter between ground and pin 1[/edit} Last edited by n[ate]vw : 08-02-2003 at 23:29. |
Be careful with Pin1. I've heard rumors that it is the pin used to get power to the OI during competitions, so it probably interfaces directly with much of the internal circuitry.
You can power the OI through pin 1, it is connected to the +9V input on the input jack from the Wall Wart.
The light in the Classic Yellow Dongle only works when powered by the Wall Wart, though. It will not light when operating on tether, where the power is supplied up the tether cable from the 'bot-terry. |
ME HELP
WE HAVE TWO DONGLES!
Give me an adress and ill send one |
#7
Thanks, but I've made one since I made this post:
http://www.chiefdelphi.com/forums/at...&postid=135152 Save it for another team that needs one =D |
| Problems with a pin... | randomperson | Electrical | 2 | 09-02-2003 23:44 |
| yellow dongle | Ryan Foley | Electrical | 1 | 24-01-2003 15:41 |
| Ugh...PWM pin vs. Speed Controller | archiver | 2001 | 1 | 24-06-2002 00:27 |
| Diagrams for wiring of 15 and 25 pin connectors | archiver | 2000 | 2 | 23-06-2002 23:03 |
| PBASIC access to 1 pin only | diego25 | Programming | 13 | 21-01-2002 10:55 |
