Go to Post By the way, a piece of advice to all those who haven't gone to Manchester for Kickoff before: Go. It's something you have to do at least once in your time in FIRST. - Billfred [more]
Unread 10-02-2003, 17:28
Laura_d Laura_d is offline
#0755 (Metallic Tigers)
Laura_d is an unknown quantity at this point
autonomous sensor programming ?
We're trying to use three sensors to track the white line in the autonomous mode. We're using 1 joystick drive. Our left sensor is on rc_sw1, pin 1, our middle sensor is pm rc_sw2, pin 2, and the right one is on rc_sw3, pin 15. I have tried lots of different things, but since I don't really understand what I'm doing I haven't accomplished anything remotely useful, and I have managed to completely confuse myself. If anyone has any suggestions as to how to get these sensors to recognize the tape and turn and basically just WORK, I would be thrilled.
Unread 10-02-2003, 17:46
Skabana159's Avatar
Skabana159 Skabana159 is offline
Robotics and Field Hockey
AKA: Jesse C. Owens
#0159 (Alpine Robotics)
Skabana159 is on a distinguished road
Send a message via AIM to Skabana159
What you should do in instances like this is write psuedo-code in english. You should try this:
If the middle sensor is on, then I want to go straight.
If only the left sensor is on, then I want to turn left.
If only the right sensor is on, then I want to turn right.
If no sensors are on, then spin in a circle.
Now, go on to write your code:
If (rc_sw2) then gostraight
If (rc_sw1)&(rc_sw3 = 0) then turnleft
If (rc_sw3)&(rc_sw1 = 0) then turnright
goto turnleft
gostraight:
p1_x = 127
p1_y = 200 'random forward speed, should be tested on bot
goto restofcode
turnleft:
p1_x = 84
p1_y = 127
goto restofcode
turnright:
p1_x = 200
p1_y = 127
restofcode:
serout ...
"What most people do not understand is that the Buddha, the Godhead, resides just as comfortably in gears and circuits as in hills and trees. To believe otherwise is to dilute the Godhead."
-Robert Pirsig, Zen and the Art of Motorcycle Maintenance
A better autonomous method.. randomperson Programming 4 24-02-2004 18:02
Electrical componenets for autonomous navigation maclaren Electrical 10 18-12-2003 02:28
crazy idea for autonomous Mike Ciance Programming 16 24-04-2003 21:50
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous Kill Switch UCGL_Guy Programming 8 15-01-2003 17:39
