Image Discuss: 258's wheels with tread.
I don't recall where it states this exactly, but I believe in the rules it states that you are not allowed to have any metal at all touching the carpet. In previous years, the carpet has been ripped up pretty bad by various forms of wheels and metalic devices, so to avoid that, no metal is allowed to touch the carpet. Try epoxy for the wheels.
Nice Wheels!
Did you guys measure a coefficient of friction for the "Team60Tread" (as we call it) on the carpet/HDPE/Wire? We measured 1.2ish for both the carpet, and the wire. But I'm curious what other teams got. I'm fairly certain use of screws in that manner is illegal. We ended up attaching our treads with liberal usage of Epoxy. I'm not sure though. FIRST has been very, confusing, in their answering of such questions. I believe the use you have is illegal in the wording of the rule, but legal if you obey the spirit of the rule. |
that's not entirely true
Team 857's wheels Last edited by ajlapp : 11-02-2003 at 09:35. |
Rule M17 also prohibits hard plastic, so wouldn't a nylon screw be prohibited if the metal screws were?
Now, based on this thread: http://jive.ilearning.com/thread.jsp...=3&thread=1536 the metal screws would be legal if they don't contact the carpet. |
what exactly is that tread made of? looks to be some kind of rubber packing material but i cannot be shure
~Pyro |
#7
Last year, we used both screws and epoxy to attach tread to our wheels, so we might have to do that again.
I'll talk to Bill about the legality of the screw usage. Thanks John! They ain't as snazzy as some other teams' wheels, but I think they're nice. We performed some rudimentary coefficient of friction testing on the HDPE (which we thought would be the most important surface to be able to grip to [take a wild guess at what we're planning to do]) with the 254/60 tread and with two different variants of the tread we used last season (I can't find a picture that really does it justice, but it was used by 192 in either 2001 or 2002 [faulty memory]). I can't remember any of the values we got for the coefficient of friction for them, but I seem to recall they were about the same (keep in mind the fact that they were rudimentary tests). We figure that if we ever get in a pushing match on the wire mesh, we'd definetly have to replace the tread on the wheels, if we use the tread we used last year (see this image's description). However, we are going to have at least a few backup treads on hand, just in case this stuff gets torn up (see ChrisH's post in this thread). ajlapp: I'll definetly have to talk to Bill about this, after seeing his post in the thread you linked... Joe: Good points. I'll be sure to perform some tests (press down on the wheel as hard as I can, and see if the screws touch the HDPE / carpet [which I'm sure they will, depending on how the belting walls bend]). PyroPhin: I'm not quite sure what it's made of (besides rubber and fabric), but according to a previosly linked thread, it's made by Brecoflex, though I can't find any online catalogs, on a cursory inspection. |
#8
How did you make the wheels?
And you can just buy some liquid rubber insulation stuff (I call it goop, you should be able to get some at an auto parts store) and just cover the screws with it, that should solve your problems I think. |
#9
<edit> After all that was done, some other kids on the team (including Jim) drilled and tapped holes for 6-32 screws to attatch the treading. </edit> <edit #2> At least I thought they were 6-32's. Maybe I'm wrong. </edit #2> Last edited by Bill Gold : 11-02-2003 at 14:14. |
#10
How'd you cut the belt? That stuff is pretty thick and rigid and doesn't seem to cut very easily.
#11
tread attachment bolts
As far as I see it, those screw heads will contact the carpet and should be deemed illegal. Of course, sometimes FIRST has been very lax during inspections in the past... but I wouldn't count on it this year.
Wheels look very similar to ours, but we wrapped tread around the side of the wheel and bolted in from the side in order to comply with the "no metal on carpet" rule. Mr. Van |
#12
We bought a curve-bladed carpenter's knife for this purpose alone, and Joe, who has cut the four current pieces of tread, has expressed at least a little malcontentedness at having to cut them, but apparently the smaller cuts are the hardest (the tapered angle cuts, and the ~1cm sideways cuts). Mr. Van: Very interesting way of attaching the tread. As I said earlier, I'll look into the legality of the whole thing later (Just about to leave the house to go to today's robotics meeting). Bill: I'm fairly certain that they were, in fact, 6-32 screws. Oh well, I'll check, and edit the picture information accordingly, later. |
| Lots of Wheels and F = u x N | archiver | 2001 | 17 | 23-06-2002 23:37 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
