Go to Post BTW - using any Lavery clue to figure anything out could be equally impossible. - Raul [more]
Unread 11-02-2003, 21:00
trollin1st's Avatar
trollin1st trollin1st is offline
AKA: Janice Bourget
trollin1st is an unknown quantity at this point
Send a message via AIM to trollin1st
Exclamation Help!!! Battery question
How long are teams averaging for battery life? Also, do people have any recommendations on how to make sure you don't run out of battery during a match? Do you use one for one match and chage it for every match? Please help since we don't seem to have enough battery life to make it thru 2 matches...
To err is human, and to blame it on the computer is more so.
Unread 11-02-2003, 21:25
Perseus's Avatar
Perseus Perseus is offline
Takin' a Break from FIRST
Perseus is an unknown quantity at this point
Batteries probably wont run out in a match if its fully charged(unless u have some sort of electrical problem). Rotating batteries is the best and probably easiest way
The Few
The Proud
The Zoroastrians
Unread 11-02-2003, 22:34
illumanat'i's Avatar
illumanat'i illumanat'i is offline
make me care
#0555
Team Role: Student
illumanat'i is an unknown quantity at this point
Send a message via AIM to illumanat'i
yeah, put in fully charged batts every round, and charge them between, (it helps to have some from other years )
Trust, Love, and Magic
Unread 11-02-2003, 23:24
Harrison's Avatar
Harrison Harrison is offline
None #0783 (Mobotics)
Harrison has a little shameless behaviour in the past
If the bot is running at full power, batteries last around 5 minutes for us....then the voltage starts to drop off.
Bring batteries + chargers from previous years for sure. But even with only 2 batteries, as long as 1 is always charging, you'll be fine when running them for only 2 minutes.
Harrison Ruess
2002/2003 Team 783 Captain
UOIT '08 Alum
Unread 11-02-2003, 23:39
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
You MIGHT be fine. Get spares. As many as you can afford up to 8. Even if you don't need them all, another team (*or alliance member*) may need a spare.
Last year with 247, we were in the heat of elim's and Truck Town ran out of spare batteries. We kept them, and ourselves in the competition by handing them one of our spares.
Unread 11-02-2003, 23:40
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
Noticing how your team number is 1073, I doubt you _have_ batteries from previous years Whenever you don't have a match, put the batteries on the charger. I'd recommend going out and getting another charger. ALWAYS check your battery before going out to a match. If you do run out of battery power, some teams with loads of batteries will be happy to lend one out...just as long as they get them back.
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
Unread 12-02-2003, 05:57
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
can't you not use other batteries in a match other than the two provided by FIRST at the beginning of the year...?
search in the electrical forum, i found something there on it.
AIM --> Woloi
Email --> ian@woloschin.com
Unread 12-02-2003, 08:48
No. http://jive.ilearning.com/thread.jsp?forum=3&thread=565
Quick release battery connector and 120 amps n[ate]vw Electrical 6 18-01-2003 23:41
Off-topic battery stuff. FotoPlasma Electrical 4 06-01-2003 12:19
One last battery question... Katie Reynolds Electrical 2 14-03-2002 08:14
Voltage Range of Analog Inputs Ulibrium Electrical 21 15-02-2002 14:11
connecting to the battery ahecht Technical Discussion 1 25-01-2002 17:15
