Visibility of Robot Controller and Reset Button
In the rules, it says the Robot Controller must be visible and the reset button available. Exactly how visible and available must the Robot Controller and rest button be?
The judges will look at your controler at inpection, before and during the match. They have to be able to see the lights and if you have problems they need to see it to help digenosie the problem. Last year and previous years you had to hit the reset button on the RC evey time you downloaded a new program but this year is resets automaticly. I personally this year have noticed that some times the RC totally locks up and you have to hit the reset button to get it working again, though cycling power on the whole robot would also do the trick.
So where should the RC get mounted? I would say visable and accesable but not in the open. If it breaks that is $565 to replace and I don't know about you but our team doesn't have that much money. Hope that helps. |
| Robot Controller Reset Problems. | Joe P | Electrical | 8 | 26-04-2003 11:56 |
| serious problem found - robot controller resets when jarred! | KenWittlief | Electrical | 23 | 19-03-2003 13:30 |
| Robot reset on OI doesn't work | Carl Owenby | General Forum | 1 | 07-02-2003 07:23 |
| Operator Interface is crazee !!! HELP | punarhero | Programming | 30 | 17-07-2002 14:23 |
| Fingers and Robot Controller | archiver | 2001 | 4 | 23-06-2002 23:54 |
