Go to Post Several really good programming and control specialists haunt CD, but a thread titled "motor failure" might not attract their notice soon. - Richard Wallace [more]
Unread 16-02-2003, 23:56
yangotang's Avatar
yangotang yangotang is offline
#0253 (MRT)
yangotang is on a distinguished road
Send a message via AIM to yangotang
Drill Motor HowTo
is there a howto floating around (with graphics) that explains the method in order to remove the pins in the drill motors?
i've seen this thread: http://www.chiefdelphi.com/forums/sh...l+m otor+pins
the only thing it has is the text directions. A graphical howto would be great for anyone who creates one!
--yang
Unread 17-02-2003, 00:02
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
http://www.chiefdelphi.com/forums/pa...er&paperid=150
this is a photo set you should be able to do it by theise
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 17-02-2003, 00:53
yangotang's Avatar
#0253 (MRT)
Cool. Thanks a lot.
Unread 17-02-2003, 19:46
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
The text description and the power point by 116 is good, but I am looking for some directions a little more descriptive than that. Does anyone have any better directions regarding taking apart the drill transmission and removing the anti-backdrive pins?
Hardware Test Engineer supporting RE<C, Google.
1999-2001: Team 192 Gunn Robotics Team
2001-2002: Team 100, 192, 258, 419
2002-2004: Western Region Robotics Forum, Score Keeper @ Sac, Az, SVR, SC, CE, IRI, CalGames
2003-2004, 2006-2007: California Robot Games Manager
2008: MC in training @ Sac, CalGames
2009: Master of Ceremony @ Sac, CalGames
2010: GA in training @ SVR, Sac.
2010-2011: Mechanical Mentor, Team 115 MVRT
Unread 17-02-2003, 20:17
Iain Iain is offline
Iain is an unknown quantity at this point
Don't worry about it so much. We managed to do it the very first time without messing up anything using only the text directions. It takes, literally, one or two minutes to do after the first time. Here's my brief layman's directions, for what they're worth:
1) Move the white clutch ring towards the input/motor end of the transmission.
2) Twist the black midsection parts of the transmission counter-clockwise. It shouldn't take much pressure to disengage it, but do so slowly. There are several free-floating parts in the transmission that will fall out if you let them.
3) The pins are one of those parts. They are two very small metal cylinders. You can't miss them, they're the only small metal cylinders in the transmission. If they don't fall out when you separate the transmission halves pick them out yourself.
4) Make sure that the metal ring with the three metal protrusions is sitting in the forward half of the transmission when you try and reassmble it; this makes things much easier than sitting it on the rear section.
5) Now, carefully examine the inner edges of the teal forward part of the transmission and the outer edges of the black rear part. The connections between the two should be fairly obvious.
6) Now this part is a bit tricky: you have to slide the two halves together while turning the output shaft of the forwad half until both the outer plastic couplings and the inner metal parts mesh correctly. It helps to have a second person turning the output shaft.
7) Once everything slides back together, simply twist clockwise until it locks into place.
Unread 18-02-2003, 14:07
DougHogg DougHogg is offline
Robot-A-Holic
FRC #0980 (The ThunderBots)
DougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud of
Here are a few other pointers on taking the pins out of the drill transmission.
To remove the pins, you have to pull back on the gear shift away from the transmission output end. Then twist the front of the transmission. Now before you pull the pieces apart, put matching arrows on the two pieces. That will help you line up the pieces to put them back together.
I recommend separating the pieces with the front of the transmission pointed straight up. You should then see the pins sitting on the rear section, nestled in amongst the other parts.
To re-connect the pieces, we found it easiest to take the parts now stacked on the rear section and piece by piece, relocate them to the front section. You will then wind up with a single gear in the rear section to nestle in to 5 gears on the front section. That takes a little bit of jiggling to get them to fit together sometimes.
Then with the gear shift still back towards the rear of the transmission, turn the two sections until your arrows line up and press the sections together. Once again, you might have to twist them back and forth a lttle to get them to come together.
Lastly twist rotate the pieces to lock them in place. (Since I don't have a transmission right here, I won't guess which way to rotate them.)
I would pull back the gear shift and put a cable tie (pull tie) on it to prevent it from coming apart and all the pieces falling out.
By the way, I also recommend that you do not store them with the drill motors inserted in the transmission, as you may find that someone picks up the combination and the drill motor drops and breaks some plastic off as happened to us.
FIRST Team 980, The ThunderBots
2002: S. California Rookie All Stars
2004: S. California: Regional Champion,
Championship Event: Galileo 2nd seed,
IRI: Competition Winner, Cal Games: Competition Winner
2005: Arizona: 1st seed
Silicon Valley: Regional Champion (Thanks Teams 254 and 22)
S. California: Regional Runners Up (Thanks Teams 22 and 968)
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
Emergency drill trade/sell Anarkissed General Forum 3 16-02-2003 22:37
Q&A Discuss: HOT drill motors CD47-Bot Extra Discussion 1 27-01-2003 13:31
