Go to Post I love math... :D - Eric W. Jones [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 21-02-2003, 22:54
iBob's Avatar
iBob iBob is offline
Extreme Mac Geek
AKA: Christopher Jones
#0240 (Mach Vee)
Team Role: Webmaster
iBob is an unknown quantity at this point
Send a message via AIM to iBob Send a message via Yahoo to iBob
Favicon Code
Ok, the favicon (little icon in the address bar). I've tried and tried again, and it still won't work. I've read through everything i've found on it, even the official homepage http://www.favicon.com So i've seen a few sites, including this one in the FIRST community and was hoping some of you fellow FIRST team webmasters could tell me what i'm doing wrong. I've made a 16x16 .ico file, saved to my main directory, added the little snippet of code and still don't see it. Does your server have to have special code or something installed? I hope someone can help, thanks in advance.
Visit Team 240's Homepage
Unread 21-02-2003, 23:42
gliebowitz gliebowitz is offline
#0075 (RoboRaiders)
gliebowitz is an unknown quantity at this point
Send a message via AIM to gliebowitz
There shouldn't be any scripting or server configuration required.
Did you save it as "favicon.ico"?
Greg Liebowitz
Programmer/Webmaster
Team 75 - RoboRaiders
www.itmediaco.com
http://www.roboraiders.com
Unread 21-02-2003, 23:56
Ameya's Avatar
Ameya Ameya is offline
Freelance Goon
FRC #0293 (SPIKE Robotics)
Ameya is on a distinguished road
Send a message via ICQ to Ameya Send a message via AIM to Ameya
You need to have the following code in your html file:
<LINK REL="SHORTCUT ICON" HREF="http://***put path here***">
That tells the browser that there exists a favicon for your site, and where it is located.
Ameya Agaskar
Team 293 alumnus
Unread 21-02-2003, 23:58
Trashed20's Avatar
Trashed20 Trashed20 is offline
Boom, Shawalala Boom!
#0862 (PCEP Lighting)
Trashed20 will become famous soon enough
Send a message via AIM to Trashed20
I think only ie 5+ supports this. what browser are you using? Also, try clearing your cashe and reloading the page.
Where has all the fun gone?
Unread 22-02-2003, 00:58
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
I thought IE just automatically searched for this file in your websites root directory. I guess that tag will force it, if it doesn't.
Brandon Martus
e-mail
Unread 22-02-2003, 01:20
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
IE definately does it automatically, as my server logs show many, many, many failed requests for /favicon.ico even though I don't have any tags relating to favicons anywhere.
As previously mentioned, are you sure it's saved in the root directory as favicon.ico and that you're using IE? Also, is it an actual ico file or just a bmp renamed to an ico? Finally, you do probably need the <link rel=... tag as your root directory isn't the actual root directory (ie you are a subfolder of your school's site).
Unread 22-02-2003, 01:49
jonathan lall's Avatar
jonathan lall jonathan lall is offline
FRC #2505 (The Electric Sheep; FRC #0188 alumnus)
jonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond repute
Send a message via MSN to jonathan lall
I believe IE looks for <siteroot>/favicon.ico and shows the icon in Favorites. It needs the link rel way to display it on the Address Bar, but only supports .ico.
Mozilla can be selected through UI Preferences to show website icons (link rels, any file format) in the Address Bar (enabled by default in Netscape), and through hidden prefs to show website icons that IE shows only in Favorites (i.e. the <siteroot>/favicon.ico file). Opera is showing the <siteroot>/favicon.ico file in the Address Bar as I go to team188.com, so it looks like it has similar behaviour to Mozilla.
Unread 22-02-2003, 09:34
iBob's Avatar
Extreme Mac Geek
#0240 (Mach Vee)
THANKS!
Thank you! I figured it out, I had to give it the direct url, not just a /favicon.ico or anything. And just to let everyone know, almost every browser supports the new favicons. I'm using Safari (Apple) and on occasion I use Chimera (a mozilla build). Both of these supports it as well as most other broswers i've used (not including IE for Mac). But anyways, thanks for all of your help!
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
Autonomous code tutorial miketwalker Programming 2 23-02-2003 12:28
Autonomous code PBoss Programming 7 14-01-2003 15:29
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
Patent source code? Kyle Fenton Chit-Chat 3 20-10-2001 17:53
