Multiple Batteries from one charger
Our 6A charger from this year is not acting fully normal (releasing "strange smells", etc) but we have 4 competetion-legal batteries. With only one charger (the old 4A heat-sink charger), we have a minor problem. Is there any method by which one charger can simultaneously charge multiple batteries?
-VenkTeam 30: We have High-Octane Lines |
Re: Multiple Batteries from one charger
He's right the ones from last year look the same, but they are not the same model. If you really needed another charger buy one from sears or something.
First, it is not legal to use any charger other than the 6A one provided this year. Second, you should never plug multiple batteries into one charger. Not only does it do you no good (4A / two batteries = twice the charging time!), but it also runs some serious risks of things releasing gas due to overcharging. In short, you're going to have to buy one (or two) new chargers that are exactly the same model as the one in the kit.
how are the batteries this year different from past ones? I have seen no difference in robot operation with either year's batteries, but we've not been carefully looking into it.
I guess we'll resort to another charger. Sniffle. Also thanks for informing me of the illegality of the old batteries (one more thing we dont have to make room for!) |
From section 3.1.1
wait last years batteries are different from this years?
I didn't notice any differences but i suppose i didn't look very closely... Now i have to figure out which ones are which. Are there any differences to look for to tell the difference? |
#9
Check the model numbers. The newer one's are model ES18-12. Last edited by Jnadke : 27-02-2003 at 21:19. |
#10
The battery is a different model.
#11
doh
#12
It says the charge current is 5.34A, but the charge rate is 6A. Will we fry batteries?
#13
It is not a high speed charger (only 1 amp) but it specifically states that you can charge up to 4 batteries. Its other claim to fame is the fact that you never have to disconnect it. It actually maintains the health of the battery by preventing sulfination which is the formation of sulfer compound crystals when the battery gets too low, or over charged. The batterMINDer also claims to break up the crystals (which degrade battery performance), and even has a special button you can push to activate a special frequency to do that. While not the right charger for quickly charging your batteries at a competition, it is great for in between events for your extra batteries. I kept last year's batteries plugged in all year. I attach the batteries together in pairs and then jumper the pairs together, and attach the charger. Our batteries seem to be in good shape. I found this link for the BatterMINDer on google.com: http://www.batterymart.com/batteryminder.php |
#14
OK here is the real poop on chargers...
1. Never try to charge two batteries from the same charger. Batteries have this bad habit of supplying current to each other (when connected in parallel) until they discharge and/or short. 2. This years batteries are slightly different from last years (new and improved) but can use last year's charger. First came out with a statement early on, that this year's battery could be charged with any previously supplied FIRST 12 volt charger. 3. Venkatesh, this years charger acts differently than previous ones. The lights on the front panel tell you that it is alternately charging and discharging/testing to determine battery charge condition. Read the manual for a complete explanation. The smell may just be the contaminants from internal components evaporating with heat. If it charges a dead battery in less than four hours it is working. 4. DougHogg, another engineer also found this Battery Minder charger but we both felt that the claims were too far fetched to be real. I am still waiting on a better test, but we chose not to buy one. "If it sounds to good to be true, it probably is." Last edited by Al Skierkiewicz : 02-03-2003 at 22:37. |
#15
I think I'll buy several of those!
| Where to purchase spare batteries? | Patrick Wang | Technical Discussion | 5 | 17-01-2003 22:10 |
| HELP - We have no batteries!! | Rick Gibbs | Championship Event | 3 | 24-04-2002 19:07 |
| 6 Volt charger...? | kangarue23 | Technical Discussion | 7 | 12-04-2002 10:35 |
| Defective Batteries? | hemihead | Technical Discussion | 17 | 28-03-2002 22:24 |
| Battery Flip-Flop... | Joe Johnson | Rules/Strategy | 28 | 20-03-2002 17:47 |
