Go to Post I think the answer you will get will be the same we have been saying since post #2 on page 1. - KenWittlief [more]
Unread 02-03-2003, 21:24
rcubes85 rcubes85 is offline
no team (TBD)
rcubes85 is on a distinguished road
Send a message via AIM to rcubes85
Parts need for Autonomus
My team want to add autonomus on our robots can someone pelase tell me the parts adn what i need to do to add it
Unread 02-03-2003, 22:11
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Remember that big blue MSC book? On page 1198 there are some pneumatic grippers used to operate the switch between driver and autonoumouse mode. Don't worry though as they are only $348.46 apiece and very eaisy to install. You will need two.
Awwww, I'm just joking. It's all in the program so you really don't need any parts. You may use sensors or encoders if you wish.
Unread 02-03-2003, 22:46
roboticscom13's Avatar
roboticscom13 roboticscom13 is offline
roboticscom13 is an unknown quantity at this point
If you mean to make your robots do things automatically like pick up balls or bins or anything in general, then you would need some sort of limit switch or switches and programing to tell the robot how long to do everything.
Unread 03-03-2003, 07:19
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
You will probably will need a 3 way switch or 2 way depending on how many Autonomus modes you are looking to add.
For example:
1- Dead Rec. Left
2- Dead Rec. Right
3- Go crazy and attack the audience
OR- You can just program the robot between matches on which program you want it to run.
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 03-03-2003, 11:45
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
Re: Parts need for Autonomus
You'll need to be a lot more descriptive of what you want to have happen.
Autonomous control is a mode of the robot. Where as a program tells it what to do (Drive forward until something happens, then turn, wait 2 seconds, turn again).. and so on without the joysticks being touched. You don't need parts to do this, unless you mean to test autonomous mode. In that case all you need is a small insulated wire or a pair of wires and a switch. Stick one end of the wire into pin 1 of the competition port, and the other end into pin 4. If you use a switch, do the same thing and flick the switch to allow a connection across the wires.
Unread 04-03-2003, 20:24
miketwalker miketwalker is offline
Robot Lifeguard
FRC #1902 (Exploding Bacon)
miketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond repute
Send a message via AIM to miketwalker
You can send me an e-mail at miketwalker@cfl.rr.com if you need help figuring out what to do. Also, check out the tutorial I wrote up on our website. It shows how to make a dead reckoning robot code. I can also show how to do an optical sensor scan if you mount them and put them into your digital inputs. I just haven't written a tutorial for that yet. Good luck!
Chopsaw? Chopsaw.
Rules on making spare parts fyi DougHogg General Forum 0 02-04-2003 16:18
Calling all Lawyers... ...Define "all parts" Joe Johnson General Forum 10 13-03-2002 15:12
Anyone else crippled by no supply of parts? aka Scott White General Forum 11 31-01-2002 10:52
What advice would you give? Jessica Boucher General Forum 8 02-12-2001 07:10
Substitute Parts BHSFirst Off-Season Events 1 08-11-2001 19:23
