Go to Post I wonder if the kit motors run counterclockwise in the Southern Hemisphere? - Gary Dillard [more]
Unread 18-01-2002, 23:17
matt sorgenfrei matt sorgenfrei is offline
#0192 (Gunn Robotics Team)
matt sorgenfrei will become famous soon enoughmatt sorgenfrei will become famous soon enough
question about atwood motor
Does anyone know where you can purchase 25 degree pressure angle gears to mesh with the atwood motor output shaft? (other than the one we were supplied with)
Unread 19-01-2002, 08:31
That was why you were supplied with it. Sorry, but it is not a common pressure angle. The other part of the cluster _is_ a common gear and you can interface with it.
This means that you will need access to machinery to mount the motor, the shaft for the gear cluster and at least one other cluster. You may have to to a machinist to have it done. Larry Barello posted a picture of a trial run he did, and some useful dimensions.
Good Luck
Drill motor change out question?? archiver 2001 9 23-06-2002 23:36
Is it weird to see an atwood motor floating in mid air? mnkysp6353 Chit-Chat 6 19-02-2002 21:38
What's with the New Motor Specs for the Atwood Mobile (Chiaphua) Motor. Robb Gerber Motors 2 23-01-2002 08:58
question about atwood motor matt sorgenfrei Motors 0 18-01-2002 23:19
Drill motor gearBox question Dennis Hughes Motors 4 11-10-2001 07:11
