Go to Post When we went to Wonderland people were like "So are you guys part of a rugby team or something?" and i was like "No...FIRST robotics! It beats rugby anyday" - Laura 1547 [more]
Unread 08-04-2003, 09:28
odin892 odin892 is offline
#0892 (team ASCII: All Students Challenging Intellect and Ingenuity)
odin892 is an unknown quantity at this point
gyro code
we used a gyro to balance our arms but the gyro would return to center after about a second or two so we made a pendulum.
here is our code before we took it out. you may need to tweak some variables.
If p3_sw_top = 1 then
If p3_y > 127 then
If balancing_motor_limit_forward = 0 then balancing_motor = p3_y
else
if p3_y < 127 then
if balancing_motor_limit_reverse = 0 then balancing_motor = p3_y
endif
endif
else
If state = 0 then
balancing_motor = 183
If balancing_motor_limit_forward = 1 then balancing_motor = 127
If gyro => 180 then state = 1
else
If state = 1 then
balancing_motor = 63
If balancing_motor_limit_reverse = 1 then balancing_motor = 127
counter = counter + 1
If counter => 30 then
state = 2
endif
else
If state = 2 then balancing_motor = 127
endif
endif
endif
Unread 08-04-2003, 10:47
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Are you asking a question, or offering your code for others to use?
Unread 08-04-2003, 14:50
i was offering code to other to use. it was supposed to be a reply but i clicked the wrong button and didn't realize.
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
Autonomous code PBoss Programming 7 14-01-2003 15:29
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
Gyro Chip Code archiver 2001 4 24-06-2002 00:57
[white paper] Auto-Balance Gyro Code Brandon Martus Technical Discussion 3 21-06-2001 10:36
