Go to Post It's official: we've run out of things to talk about. - Jessica Boucher [more]
Unread 23-01-2002, 22:23
nwagers nwagers is offline
#0240 (Mach Vee)
nwagers is an unknown quantity at this point
Send a message via AIM to nwagers Send a message via Yahoo to nwagers
Lightbulb drill motor transmissions
Does anyone know the size of the ring needed to lock the drill motor transmissions into low gear? I know where/how to install it. But I am not sure on size. I posted some information on locking the transmissions into high gear in the Whitepapers section.
Unread 23-01-2002, 22:45
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Exclamation Lock'n Low
29 mm I.D.
33 mm O.D.
5 mm Thick
I made mine in Aluminum - Works great!
Ed Sparks
MECH TECH FRC-3959
Unread 24-01-2002, 20:17
dense's Avatar
dense dense is offline
#0907 (Cybernetics Core)
dense will become famous soon enoughdense will become famous soon enough
a clarification...
I'm not sure if I understand, but what are the o-rings used for and what are you trying to do with drill motor?
Are you trying to lock the the planetary gear transmission on the drill motor?
And lastly, is 1 or 2 on the drill motor casing the low geared reduction?
Thanks in advance
let the aliens invade
-shafi, dweller of earth
- 2002 Can. Regional - J&J Sportsmanship Award
- 2002 Can. Regional - Top Rookie Seed Award
- 2002 Can. Regional - Delphi 48 "Play Of The Day Award"
- #3 seed, quarter-finalist with alliance 247 and 885
Unread 24-01-2002, 21:46
Kit Gerhart's Avatar
Mentor, coach, whatever--
FRC #0233 ("The Pink Team")
Can someone explain
Can someone tell me about the aluminum rings, etc. that you use to lock the drill gear boxes in low or high? We have shifted them since '99, but before that, we always locked them in gear with a cable tie between the little shift fork and an appropriately located item nearby. It always worked fine. What am I missing?
Thanks
Team 1062, The Storm, 2003
Unread 24-01-2002, 22:06
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
High gear is easy...
To lock the gearbox in high gear (faster output, lower torque) all you have to do is put the plastic ring in "upside down" (motor side shaft side?).
If you do this, the teeth on the outside of the ring cannot mate with the teeth in the housing and thus you cannot shift it into low gear.
Low gear requires a machined ring or an o-ring to lock.
As to Kit's question about why anyone would want to put anything inside the transmission when you can hold something outside the transmission just as easy, for many of us, that whimpy shifting ring is not good enough or it is just in the way of our machanism or mounting system.
Joe J.
Unread 24-01-2002, 22:32
#0240 (Mach Vee)
clever idea, but how does the ring do with all the extra space to move around?
also, the first plastic ring (the smaller off-white one) tends to melt/strip in a few of our trans. what might be the cause of this?
Unread 25-01-2002, 08:22
AKA: Dr. Joe
FRC #0088 (TJ2)
As to your first question, I don't know because Chief Delphi has not used the drill transmissions in many years. When I did, I used machined rings to lock the transmissions. The "flip the ring over" idea comes to me from Bill Beatty (though he is by no means the only one who suggested it). Based on the source, I would say it must be a pretty solid method. Unless my brain is fried and I am mis-remembering the source.
As to your second question, I have NEVER had any problems with that first ring. I have never even HEARD of any problems like this.
Are you using it with the drill motor only or have you made a homebrew of motors to input into this transmission?
Anyone else have ideas?
Joe J.
Unread 25-01-2002, 11:58
dense's Avatar
I don't see why you can't just duct tape it down? hehe
Or screw it down, it seems a little too much work too machine a custom piece just to hold the gear assembly.
Just my insight
Unread 26-01-2002, 07:47
#0240 (Mach Vee)
As to the rings it only takes about 10 to 20 mins to make each one. Twenty mins out of 1000's of man hours isn't that much for a fail safe way to do it. As to Joe's question: We only use the drill motors with the trans. The trans are from 2000 and were used in competition. We never had this problem then. Would that have anything to do with it? i.e. wear and tear?
Unread 26-01-2002, 21:41
While these various rings, etc. may be a 'better' way of holding the transmission in high or low gear, it will be hard to convince me that it is necessary to do anything other than use the fork that comes with the drill and "tie" it into the gear you want.
We did that from '96 to '98 and won nationals in '98 with such an arrangement. Also, while it is not considered the ultimate in technology, we had the drill motors and gear boxes in the drill cases those three years.
While I completely agree with Joe that drill gearboxes held in gear with tie wraps, and mounted in drill cases are not the ultimate setup, a rookie team with limited resources who wants a robot that will move reliably can do very well with a simple drive train using drill motors and transmission mounted in the drill cases.
Unread 26-01-2002, 22:21
Woodie Flowers Award
Bill Beatty Bill Beatty is offline
#0071 (Team Hammond)
Bill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond repute
Locking In High
Joe,
You are correct. We have used the filpped ring gear every year to lock in high. It is quick, easy and free. It actually appears to improove the mesh a bit. Never had a gearbox failure in six years. (Now I've done it)
Unread 26-01-2002, 22:23
Oops
Not last year, cause we shifted.
Unread 26-01-2002, 22:25
David Kelly's Avatar
David Kelly David Kelly is offline
A Legacy of Impact
FRC #0234 (Cyber Blue)
David Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond repute
Send a message via AIM to David Kelly Send a message via Yahoo to David Kelly
we've used the plastic ring off of a plastic coke bottle before to lock it into gear. it seemed to work like a charm. but you do have to file down the little plastic things inside it
2010 Indiana Robotics Invitational Planning Committee
2010 Boilermaker Regional
Chairman's Award, Regional Finalist
2010 Kansas City Regional
Entrepreneurship Award
2010 Championships
Autodesk Inventor Award Winner
Unread 26-01-2002, 22:50
Coke bottles and sleepless nights ....
David,
What line on the additional materials list has "plastic ring off of a plastic coke bottle" or is it a Small Parts item (P/N Pleeezzzz).
As for why make a locking ring, it's one thing less to worry about and worth the manufacturing time. I'll loose sleep about 100 other things, but not the transmission slipping into (god forbid) NEUTRAL. argggg!
Ed Sparks
MECH TECH FRC-3959
Unread 26-01-2002, 23:39
A Legacy of Impact
Re: Coke bottles and sleepless nights ....
Originally posted by Ed Sparks
David,
ummmm... it's not. we used that in '00. last year we held it with tie wraps and this year we're planning on switching gears. sorry everyone for breaking the rules in '00. not like it would have mattered. we sucked really badly that year
2010 Championships
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
Emergency drill trade/sell Anarkissed General Forum 3 16-02-2003 22:37
Q&A Discuss: HOT drill motors CD47-Bot Extra Discussion 1 27-01-2003 13:31
