Does anybody know where to buy a good wheel for robot?
Thanks ![]() |
I just opened our shipment from skyway.......
I ordered some of the 9" pneumatic and some of the 9" bead-lock and my initial opinion is forget the bead-locks and go with the pneumatic tires. They are ohhhhh soooo stickey and reasonably light. The bead-locks with the Dupont whatever-it-is tires are somewhat soft but are heavy and do not adhere to the carpet nearly as well as good ole rubber. I've just designed an adapter to adapt the 3/4" hub in the pneumatic wheels down to 1/2" and will post it in the "Manufactured Parts" library of the FIRST CAD Library. My only decision is weither or not I want to stick (no pun intended) to my homebrew (sorry: top secret) wheels at 6" or go with these 9" monsters. hmmmmm...... Skyway Wheels |
If you're not going to build your own, skywheels have some decent stuff. You should look back to this thread for more info:
http://www.chiefdelphi.com/forums/sh...5&goto=newpost We had a nice little debate over buying wheels or making wheels or tracks...good stuff. |
We made our own wheels. We used 6" circular solid aluminum (available from SPI) and took out some weight with holes, and added a built-in hub and bearing.
| Who used wheel encoders | CyberWolf_22 | Technical Discussion | 12 | 04-05-2003 15:37 |
| 3D Model of skyway 20" wheelchair wheel?? | Elgin Clock | 3D Animation and Competition | 2 | 14-09-2002 16:41 |
| wheel hub kit and sprocket | archiver | 2001 | 7 | 23-06-2002 23:27 |
| wheelchair wheel + F.P. motor ?? | archiver | 2000 | 2 | 23-06-2002 22:44 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
