Go to Post In most cases on FIRST robots, we have more material than in we need in some places and less than we need in others. That single phenomenon is the leading cause of robot failures. - Paul Copioli [more]
Unread 03-05-2003, 14:52
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
Horsepower of Kit Motors?
I know the drill motor spec sheet tells a Horsepower rating.. and I know some teams have done their own testing to verify spec sheet promises..
Has anyone found maximum horsepower ratings for all the kit motors this year? If not all.. at least some? i.e. FP, Globe, and Van Door
Unread 03-05-2003, 15:23
Gadget,
Again you have to refer to the tables for output power as related to RPM on the motors in question. There is a conversion factor, Watts x 0.001341 = Horsepower. This will allow you to convert from watts to horsepower. You can find more conversions at http://www.watb.net/info/c_factor/power.shtml
Unread 03-05-2003, 15:37
Gadget470's Avatar
A Fire Outside
Problem is, only the Drill and Chiaphua motors say the Watts Out at max power or the efficiancy of the Watts In
Unread 03-05-2003, 20:29
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
You can calculate the Watts Out at max power yourself, you just need to know how.
Check out my lecture notes: "WRRF motor selection workshop lecture notes... "
It's under the technical sections in white paper. Here is a link to it: http://www.chiefdelphi.com/forums/pa...C&pagenumber=2
Hardware Test Engineer supporting RE<C, Google.
1999-2001: Team 192 Gunn Robotics Team
2001-2002: Team 100, 192, 258, 419
2002-2004: Western Region Robotics Forum, Score Keeper @ Sac, Az, SVR, SC, CE, IRI, CalGames
2003-2004, 2006-2007: California Robot Games Manager
2008: MC in training @ Sac, CalGames
2009: Master of Ceremony @ Sac, CalGames
2010: GA in training @ SVR, Sac.
2010-2011: Mechanical Mentor, Team 115 MVRT
Unread 04-05-2003, 08:32
I've always used 746 W = 1 H.P.
A 400 kW Mercedes engine has 300 H.P. in the U.S.
And since electric motors are really efficient, use Watts Out = > 0.9 times Watts In = Volts x Amps. (The approximation is useful because your input data are approximations too.)
If you have to figure Watts out, you can also use torque times revs :
W - F x d = F x [v x t] = (T / arm) x (rps x arm x 2 x pi)
J = N x m = (N.m/m) x (cirumferences-per-second x length of circumference) = (N) x (length) = F x d = W
Unread 04-05-2003, 18:00
Gadget470's Avatar
A Fire Outside
To anyone following this thread, or who just may want to know, the following is the maximum horsepower ratings for the 2003 motors.
Drill: .504
CIM: .4562
F-P: .1987
-w/ GB: .121
Globe: .053
Van: .0889
Window: .0074
Information found with the help of Ken and Al's posts, thanks a lot guys
Unread 04-05-2003, 19:16
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Errr from what I have read the reverse is true. How efficient is really efficient by your standards??
Unread 04-05-2003, 19:37
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
He used 90% in his formula.
Unread 04-05-2003, 19:39
Adam Y.'s Avatar
Adam Y.
no team (?????)
Yeah that is not really smart to do unless you know your dealing with rare earth magnet motors which generally have high efficiencies. This really is not smart to do with the motors First gives us.
Unread 05-05-2003, 02:58
DougHogg DougHogg is offline
Robot-A-Holic
FRC #0980 (The ThunderBots)
DougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud of
Wouldn't it be that a 300 kW Mercedes engine has 400 H.P. in the U.S.?
FIRST Team 980, The ThunderBots
2002: S. California Rookie All Stars
2004: S. California: Regional Champion,
Championship Event: Galileo 2nd seed,
IRI: Competition Winner, Cal Games: Competition Winner
2005: Arizona: 1st seed
Silicon Valley: Regional Champion (Thanks Teams 254 and 22)
S. California: Regional Runners Up (Thanks Teams 22 and 968)
Unread 05-05-2003, 03:22
Robot-A-Holic
Drill: .504
CIM: .4562
F-P: .1987
-w/ GB: .121
Globe: .053
Van: .0889
Window: .0074
Given the above information, can anyone explain to me how WildStang was able to use 2 Drill and 2 F-P motors, one on each rotating wheel, to go in any direction, without the Drill motors overpowering the F-P motors and throwing the whole bot into a spin.
I guess to go sideways, you could throttle back the Drill motors to match the F-P motors, but then wouldn't you have .1987 * 4 = 0.7948 effective horsepower versus 1.08 horsepower for 2 Drill motors alone?
Am I correct in assuming that WildStang was able to move faster in a forward direction that in a sideways direction?
Unread 05-05-2003, 06:59
Gadget470's Avatar
A Fire Outside
The values I posted are the maximum values of horsepower.
Horsepower is a relationship between RPM and Torque. When running the drill with no load and no gearbox, you won't get .5 HP out of the motor.
Take the following equation: Torque * (RPM/5252) = Horses
Now yes, you may be getting more horsepower to wheel A and B and less on C and D, but that's OK.
The wheels were "speed matched" where the final stage of gear reduction left all wheels with the same speed by having different ratios.
Wildstang, and others using the same setup, achieved a certain speed and horsepower by matching the speeds while having different torque values to the sets of wheels.
If I'm not mistaken, correct me if I'm wrong please, WS probably had drill putting out ~.4 HP and the F-P's putting out ~.05
.4 + .4 + .05 + .05 = .9 HP
Unread 05-05-2003, 11:46
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
Maximum Power (in Watts) output is typically calculated as:
Power = (Max Freespeed / 2) * (Stall Torque / 2) * Conversion Factor
Maximum Power (in HP) can then be calculated as:
HP = Power / 746
Really, horsepower is a misleading and useless number. Power output (in Watts) is by far a better and more accurate comparison. When coupled with efficiency, it's the best comparison.
Horsepower and Watts are the same thing, but HP is an Imperial Unit and the Watt is the SI (metric) unit. SI units are by far better units to use, because you will use less conversion factors (less screw-ups) when moving between Power output and Electrical input. However, remember to mention you are using SI units in all your calculations or you might end up like NASA!
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 06-05-2003, 02:20
Robot-A-Holic
That makes sense. I guess if they got in a pushing match going sideways, they could have some interesting differences in the wheel behavior due to the "different torque values".
HP = Power / 746
Thank you. That link is a very cool source of info on motors. Who knows. If I can get some time to study all the tutorials on that web site, one of these days I might understand what our mechanical engineers are doing.
Unread 06-05-2003, 10:01
To answer many of the above questions...
The different motors we used were matched to different transmissions so that the wheels were close to match. Any fine tuning could then be done in software. Knowing which side the drills were on then set what side of the robot was used for power, pushing, etc.
Using watts for motor output power helps solve a number of problems in design. You know what the output power is and you can measure the input electrical power, so with a little calculation you can determine efficiency. Power out/power in=efficiency. So what does that tell you? The power lost in the conversion has to go someplace. The result is heat. So in the case of the Bosch motor running at 376 watts out with 672 watts input, efficiency at 56%, then 296 watts go into heat. Yes that's like three 100 watt light bulbs in each motor doing nothing but generating heat. That is the heat that changes the motor internal resistance, melts the bearing lubricants, detaches the fan and unsolders the motor wires. In many cases in electrical systems, it is very important to get rid of the heat generated in the system. Things like CPU heatsinks and power supply fans in your computers prevent that heat from building up to point where the physical properties start to change. In solid state electronics, the heat generated internally can cause more current to flow, which in turn causes more heat, and so on. The tech term is "thermal runaway" and many devices are designed to shut down when the temp gets too high. The three terminal regulator, 7805, will cutback on current or shut down completely if it gets hot, for instance.
Q&A Discuss: How many Van door motor(s) come with the kit? CD47-Bot Extra Discussion 1 08-01-2003 11:07
How many Van door motor(s) come with the kit? Ken Leung Kit & Additional Hardware 7 07-01-2003 21:40
