| View Poll Results: Did you use the Beta Stamp Editor? With what results? | |||
| We didn't use the Beta editor. |
2 | 10.53% |
| We used it with no problems. |
15 | 78.95% |
| We tried it, but had problems, so abandoned it. |
0 | 0% |
| We had problems, but found work-arounds. |
1 | 5.26% |
| We had problems, and Parallax provided us a private release. |
0 | 0% |
| We had other non-tokenizer-related problems. |
1 | 5.26% |
Other. (I'm not sure what other possibilities there are, but someone is sure to want an Other option )
0 | 0% |
| Multiple Choice Poll. Voters: 19. You may not vote on this poll | |||
Impending BASIC Stamp Editor Beta 2 release
This text has been added to Parallax's "More information" page for "BASIC Stamp Windows Editor version 2.0 Beta 1":
But I am a little curious about the statement "Beta 2 will include adjustments to the PBASIC 2.5 tokenizer...". I'm guessing there must have been problems with the tokenizing. (Or maybe they are just making it more efficient?) Personally, I never encountered any problems, so I'm adding a poll to this thread. Did any of the rest of you see problem with the tokenizing? (By that I mean that some perfiectly valid code either would not compile or did not execute correctly.) If you encountered a problem, did you report it to Parallax? If you reported a problem, what kind of response did you receive from Parallax? (Goya, you mentioned a possible problem with DO...WHILE...LOOP. Do you still think it is a bug? Did you report it? Did Parallax say anything?) |
Our hacks were all our own - as best as I could tell
We used the editor on a combination of old and new desktops and notebooks from an couple of old P-200's to new P4's and Celeron's The code execution all seemed consistent. |
we used the beta as soon as it came out, had not one single problem.
it had a few things that made the code much easier to read/write (like the select case). i'm hoping next year we have a better language, but if all we get is PBASIC, i'll take 2.0 over 1.33 any day. |
My view on the new tokenizer is that it'll only make tokenizing more efficient. |
yeah, we'd have to learn a new language, but anything is better than PBASIC. i don't see why we can't have the option to use the Java chip, or some sort of C/C++ chip. if there was a way to swap out "modules" or switch a jumper to use a different chip, it'd make so much more sense, while allowing us to slowly move away from PBASIC, which, well, has shown this year, and is bound to show even more next year, how underpowered it is for true autonomous applications. but back to the topic at hand... |
It's here!
The Beta 2 release is out there on the Parallax site. The ReadMe lists some very attractive features:
i'm happy with this new version, but it's still the hardware which limits us. until we can do simple math, out to at least two or three decimal places, it makes some things so much more complicated.
for instance, this year, to try and make the drills spin the same speed (since they go faster forwards), we had to come up with some formula. we had me, dan, a computer scientist, and a girl who's really good at math. in the end, we had a formula, but it was constantly off by about 20 units. solution? i added a constant. we tried to find out why we needed the constant, but we couldn't figure out how it fit in. we just accepted it, and moved on, cause we had no time to spare. if we're going to have more and more autonomous segments, we're going to need much more control, much more speed, and much more memory space (ok, the scratchpad is good, but it can get very confusing if you use it a lot). there are plenty of solutions out there (everything from a Javalin chip to embedded linux), i just wish we had some way to make use of them in FIRST. |
#9
Learning Assembly would take way to long (I'm saying this because Ian said anything is better than PBASIC). |
#10
Yeah, Assembly might not be as good, but at least it actually has a use in the real world, whereas PBASIC, I've never heard mentioned by professionals. So at least with Assembly, you'd be learning something you might need to learn later on anyways.
| Auxilliary Basic Stamp Chip | Kai Zhao | Technical Discussion | 9 | 07-01-2003 21:21 |
| no basic stamp found! | DLyons | Programming | 7 | 23-12-2002 22:17 |
| I Need Help with downloading Basic Stamp Program | archiver | 1999 | 2 | 23-06-2002 21:57 |
| Is anyone using the BASIC Stamp Preprocessor? | Greg Ross | Programming | 4 | 12-02-2002 12:24 |
| Question about Basic Stamp | miketwalker | Programming | 3 | 14-01-2002 13:10 |
